February 23, 2025, 12:07:40 AM *
Pages: [1] 2   Go Down
Author Topic: S2R800 Fork Question: Options?  (Read 3412 times)
faolan01
« on: March 15, 2012, 06:43:55 AM »
So the the non-adjustable Marzocchi forks that came stock on my 2006 S2R800 are sorely in need of upgrading/replacing, but I'm not sure which way to go about doing it. There is so much information on different things that people have done to their suspension that I'm left feeling a bit bewildered going through all of it, so I decided to post a request based on my specific criteria. Here goes...
Currently I weigh 212lbs, so I'm definitely heavier than the stock forks are designed for. I've started trying to loose weight and have a goal weight of 180lbs, which is a lot closer to what they are made for, but still over it. I also like to take a lot of day trips and occasional overnights, and when I do I load up my tank bag with probably up to 10lbs worth of stuff (not sure, never actually bothered to weigh it before a ride), and I have a few friends who are frequently asking me to take them on rides. All this adds up to weight being a bit of a moving target, so going adjustable would be ideal but may not be in the budget. I have set a hard limit on what I can spend at under $1000, preferably under $800. I just finished paying off my credit cards and really don't want to immediately dive back into debt with them. I also don't have tools or a space where I can prop up the front end, so I can't do the work myself.
I figure the 3 options are:
1) New springs, valves and oil.
2) Adjustable cartridge kit
3) New forks
Option 1 is probably the least expensive, but with weight being such a changing figure is it worth it to spend the money on a non-adjustable solution? If I do go with that, do I use my current weight to determine the springs/oil/etc and risk ending up with the front end being way too stiff when I do reach my goal weight, use my goal weight and have it too soft until I get down to that, or aim somewhere in the middle?
Option 2 gives me the adjustablity I want, but I'm not sure if there are adjustable cartridge kits for my forks and if there are they may not be in my price range.
Option 3 is one I know a lot of people will probably recommend, but may be more expensive and/or involved than I can do right now. If I were to go with SBK forks from ebay I know that it would most likely also mean modifying/replacing the upper and lower triple, potential clearance issues for the controls, caliper mounts may require new calipers, etc. Since I don't have the option to do the swap myself this would also involve calling a shop and having them do all the work, so labor adds into the final price.
So......help?
faolan01
« Reply #1 on: March 15, 2012, 06:46:34 AM »
Oh, almost forgot...I live right next to Boston, MA, so if anyone can recommend a place relatively close to me to have the work done that would be great  Cheesy
Dirty Duc
I'd rather be an anti-
« Reply #2 on: March 15, 2012, 07:05:23 AM »
Option 4 = set of adjustable forks from fleabay.  I scored a set 3-way Showas with linear springs that feel right, sold as for an ST, but the right length for a Monster ($300).  Changed the fork oil and called it a day.
faolan01
« Reply #3 on: March 15, 2012, 07:22:53 AM »
that's another option. which models/years had forks that are a direct swap for the 50mm top, 54mm bottom forks on the S2R800?
Dirty Duc
« Reply #4 on: March 15, 2012, 08:46:05 AM »
I think monsters from this millenium and all STs.  The STs are a little taller, so depending on your handlebar setup you may need to make some adjustments to either ride height or handlebars (a search here will yield significantly more information on the particulars).  I was already running a 60 series in the front, so I figured the less than an inch or so could be compensated for by raising the rear a little.  (as you can see, I am very scientific in my measurements, and I will surely die because there is no way my bike is set up like anyone else's and I do my own work)
The important thing is the caliper mounts.  I forget what the measurements are called, but as long as the mounts are shaped the same as the ones on your S2R, your calipers will mount up.
The only other thing you will need is a front axle with holes in it to adjust the adjuster on the bottom (compression?).  I drilled holes in mine with a drill press.  You can buy one for not too much money.
corey
'06 Tang/Black S2R800
« Reply #5 on: March 15, 2012, 10:52:46 AM »
Nice set that should bolt right on:
http://www.ducatimonsterforum.org/index.php?topic=55618.0
$300 isn't bad.
« Reply #6 on: March 15, 2012, 10:58:46 AM »
Yeah, the showas are the right route.  Get them sprung for your weight and oil change and you're in the money
« Reply #7 on: March 15, 2012, 10:59:01 AM »
$300 isn't bad.
Those are early style, non-adjustable, small axle, 40mm caliper mounts.
No workie on S2R800.
« Reply #8 on: March 15, 2012, 11:02:59 AM »
Huh?
the forks came from a 900 monster which was a model year 2000 or newer.
they have 65MM brake caliper bolt spacing and a 25MM axle.
battlecry
On a silver black phantom bike...
« Reply #9 on: March 15, 2012, 11:03:46 AM »
I went with AK-20 cartridges and have no regrets.  If they are close to your price range, you might consider them.
Dirty Duc
« Reply #10 on: March 15, 2012, 11:04:09 AM »
Oh yeah, and get a Penske for the rear.  Makes a much more hugerer difference in the handling.  Dolph
« Reply #11 on: March 15, 2012, 11:14:37 AM »
A couple of hours away, but well worth the trip.  Board sponsor and expert in all things Ducati, including suspension.  Eric did my forks and he did magic.
http://www.clubhousemotorsports.com/
« Reply #12 on: March 15, 2012, 11:16:45 AM »
My mistake.  Tongue
Berg was *looking* for 40mm caliper spacing small axle forks.
Those forks are non-adjustable, however.
faolan01
« Reply #13 on: March 15, 2012, 04:45:03 PM »
Thanks. Emailing clubhouse and traxxion for more info, and still looking around for other options. Does anyone know if there's any sort of chart or anything that lists fork dimensions by model/year? Also, more suggestions are definitely welcome.
« Reply #14 on: March 15, 2012, 06:31:16 PM »
there are only two fork dimensions
Monster, ST, SS.
SBK
The ST are a bit longer than the Monster and SS, but they are widely used.  You just have to be concerned about getting the right axle/caliper type and that is the year (1999 and later is 25mm axle)
Pages: [1] 2   Go Up
