Post 2000 Clutch Slave Cylinder Rebuild
Started by koko64, March 16, 2012, 01:07:09 PM
Quote from: koko64 on March 25, 2012, 02:52:07 AM
DP, Tiz, SD, Brad
Any reason why an appropriately sized o ring in the correct material wouldn't work? It seems they were plentiful and cheap in the auto brake/clutch workshops.
I will go back to the seals specialist I talked to and see if I can trial an o ring . Could be a cheap fix.
Evoluzione uses 2 standard o-rings on their 'upgrade' pistons.
It'll probably work...not sure how long.
What kind of seal in the early model stocker? O ring?
Quote from: koko64 on March 25, 2012, 04:33:25 AM
IIRC it's a single lipped seal.
Thanks
I'll let you know what seal I end up with and how long/if it works.
Cheers
Düb Lüv
I did the evoluzione upgrade and it still seems to weap a little fluid still after the rebuild. Ill probably pull it apart again. also i just went back to find them and it seems that evoluzione went out of business.
Building, building, building
What did they want for that? Is it for the old or new slave cylinder?
Quote from: koko64 on March 25, 2012, 11:07:51 AM
I believe they sold for about $20 US.
Old style.
Bugger it.
That late model slave cylinder is getting an o ring, possibly in AFLAN.
Düb Lüv
Quote from: ducpainter on March 25, 2012, 11:12:00 AM
Old style.
From my invoice.
$30usd + shipping $6.00usd
Part # 90050-03
Replacement piston for 91-2000 external slave bikes
I saw some of evoluzione's parts on eBay. I believe it's then selling off inventory.
Here's the sellers sales page
http://shop.mobileweb.ebay.com/searchresults;PdsSession=4afa762f1360a5abe8c787a7fffcdeb5?cmd=SSID&pg=1&sellerId=gc748s
Quote from: koko64 on March 25, 2012, 11:49:13 AM
Not bad with a new piston included.
Aren't the later slaves larger id?
Sleeve and the A/M piston and o-rings? [evil]
They are selling the slave cylinders for $125 and the piston/seal kit for $22.50.
Nows the time..
Quote from: ducpainter on March 25, 2012, 11:50:38 AM
Yeah I'm guessing a mm or two bigger at 26mm. Spose customers wanted an easier clutch pull.  I'll see the local guy for some o ring type seals for the late model slave. Wouldn't be hard to machine another o ring groove in the late model slave piston.  A mate would do it for a beer. I could use off the shelf seals.
Pounce on those ebay deals guys.
