Post 2000 Clutch Slave Cylinder Rebuild
Started by koko64, March 16, 2012, 01:07:09 PM
Just a correction, the latest seal material is called AFLAS. It is the replacement for epdm/n which is sensitive to some of the new additives in brake/clutch fluid.
Some of the late oem and aftermarket slave cylinder failures may be due to these new additives and not design flaws or faulty seals. Could be a case of one technology jumping ahead of another in some cases.
I will get a spare new style oem seal from Brad and send the old one away to be made in AFLAN for $30 locally or probably cheaper via Ducatiz's contact. But I also do intend getting  grooves machined into the piston of the late style oem unit to accommodate the two $1-00 o rings that I have sourced locally. They were epdn however.
So I am looking for other leaky late style slave cylinders to do some R&D. Maybe the oem type seal and at least one o ring will make it leak proof.
I'll check in with Brad and Tiz after Easter/Passover.
Cheers.
