Header pipe options
Started by ducmeister, March 24, 2012, 03:07:05 AM
ducmeister
Hi all,
Finally gave the bike a good clean up today after way too long.  Something that's always disappointed me about my bike is the crappy looking header pipes.  The carbon cans and the pipes attached to them look great but the header pipes have always looked dull and almost rusty.
Does anyone know of options for good stainless or titanium header pipes?
Cheers.
'02 M900ie, DP CF mufflers, DP mirrors, CF side covers, beer tray, belt covers, and sprocket cover, K&N filter, clear indicators, Speedymoto 5 spoke clutch cover, etc, etc, ad nauseum.
vossy
Maybe you could see what the price difference is between getting your header pipes either chromed or ceramic coated as opposed to buying new stainless pipes
good luck with it.
"Life's short" "Ride More"
Staintune used to offer a big bore pipe in polished stainless for the early Monsters. Same shape and style as the oem, but a few mm bigger bore pipe with the crossover section opened up and given a smoother looking radius. Look alot like the FBF pipes Dub Luv is selling.
The staintunes appear beautifully made and finished too. They should still have the jigs.
kyle
Strip the whole system off, clean it up good and proper then get it ceramic coated.
Mine has staintune high mounts, I am about to do this with mine and get the whole lot (pipes and all) black ceramic coated. Should be ~$150 all done.
ducmeister
Hmm, I think I'm tempted to go the shiny look over the black ceramic coating.
Might get in touch with Staintune.
Cheers.
Twizted
This works well if you want to go the cheap option. This method cleaned my rusty old header pipes up.
http://www.ducatimonsterforum.org/index.php?topic=43917.0
suzyj
#6
Speaking of which, do I need new exhaust flange seals if I remove the headers, or only if I damage the existing ones during removal?
Ignore the weird woman.  She's an idiot.  There doesn't appear to be a seal or gasket.  There's a block that's welded to the end of the header, which seals against the head.  Kinda hard to damage that.
brad black
there's a round metal covered fibre gasket at the head, generally hard to see.  037084005 .
Brad The Bike Boy
http://www.bikeboy.org
brad black
how about an acid dip or bead blast then mop n glo?
Brad The Bike Boy
Rowdy
I had mine ceramic coated silver. They were looking sad after a few years of use but came up good as new. Gave them to the coaters uncleaned. The options were Black or Silver. Silver was a lot cheaper and suited my bike more.
Cost about $200.00 for the headers and the mid pipe to get done. Took about one week.
I would not look at chroming the pipes. They will start to pit and rust.
You greatly underestimate the amount of overconfidence I have.
ducmeister
That job with the WD40 looks really good for the price.  I'm tempted to give it a go.
Brad, what is "mop n glo"?
rendang
    Do they mean Mop n Glo the floor cleaner ?  Its the only thing I can find   ???
S2R800,    0    , 750 GT, Rickman Honda, 450 'Silver Shotgun", 750 Sport, 250 Mark 3, Kwaka 500 triple.
ducmeister
Quote from: rendang on March 31, 2012, 02:20:10 AM
I reckon so.  It's probably got wax in it that will seal the outside of the pipe once applied.
I think I'll give it a go.
