February 22, 2025, 11:42:07 PM
Rear disk and speedo sensor's
Topic: Rear disk and speedo sensor's (Read 1281 times)
BRH
March 25, 2012, 11:16:00 AM »
Hi, can someone help, Iv brought a new wavy rear disk for the M1100, but it hasn't got the 4 metal studs for the speedo to read, just 4 holes. So I used 4 stainless steel allen key bolts though the holes that look ok, but the sensor doesn't seem to read them, so my queston is, what metal do I need to use for the sensor to see them ?
Any help would be great.
Thanks.
Re: Rear disk and speedo sensor's
March 25, 2012, 11:17:48 AM »
You need regular steel, not stainless.
March 25, 2012, 11:18:48 AM »
You need a bolt that is magnetic.
Some stainless is, but you'd have an easier time finding a plated mild steel bolt.
I think one of the four will do it...I could be wrong about that.
BRH
March 25, 2012, 12:04:15 PM »
Great thanks, your dead right, Iv just put a magnet to my allen key bolts and they're not sticking, so il get some that do.
2001cromo
March 25, 2012, 05:55:49 PM »
Just an FYI - Like Speeddog and Ducpainter pointed out, the speedo needs all of the bolts to be magnetic.
If it's got 4 bolts, than it's a SSSA
If it's got 6 bolts, than it's a DSSA
and the speedo is specific to each type of swingarm.
As the speedo is counting the # to determine a full revolution of the wheel. Woulda made more sense to use just 1, but that's not the case...
March 25, 2012, 06:06:36 PM »
Quote from: ducpainter on March 25, 2012, 11:18:48 AM
You are.
My 999 wheels with the 5 bolt brake disk read about 20% low compared to my 6 bolt stock disk. It's SpeedoHealer time!
