February 22, 2025, 07:15:41 PM *
Author Topic: help me find some clip ons  (Read 1956 times)
JoeP
« on: March 26, 2012, 08:09:35 PM »
My 01 monster has about 1 1/8 in of fork sticking up through the triple. Anyone know if there are clip ons that I can mount above the triple without having to move the forks up or down? I tried a set of Drivens* but the clamp height was too large and went above the top of the fork legs.
*now in the "parts for sale" forum...
seanster
Wat???? Hero Member!?!?
« Reply #1 on: March 26, 2012, 08:12:28 PM »
http://motowheels.com/i-6922767-mw-billet-clip-ons-w-risers-monster.html
Try that...
I'm saving to get one too.
JimmyTheDriver
« Reply #2 on: March 27, 2012, 06:55:58 AM »
Consider something like this?
http://www.speedymoto.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=08-0250BLK&Category_Code=TB
You can mount them under the triple, but they aren't going to break your back.  Triple take all of 2 minutes and a rubber mallet to get off.  Plus you can move them up and down under the triple to achieve desired height.  I have them on my S4R and love them.
Not my bike, but gives you an idea...
-Jim
JimmyTheDriver
« Reply #3 on: March 27, 2012, 06:57:59 AM »
These are also pretty neat, as you don't need to remove the triple to install!
http://www.revzilla.com/motorcycle/woodcraft-clip-ons-with-risers?utm_medium=base&utm_source=Google&utm_keyword=woodcraft-clip-ons-with-risers&utm_campaign=Clip+On&adtype=pla&kw={keyword}&gclid=CMCeuaqrh68CFYbe4AodlWfa9g
corey
'06 Tang/Black S2R800
« Reply #4 on: March 27, 2012, 10:38:33 AM »
i think you may be hard pressed to find something that narrow.
apex mfg bars seem to have a nice, narrow mounting bracket, but even that is about 1.75"...
i have woodcrafts with a 2.5" rise under my triple, works like a charm.
JoeP
« Reply #5 on: March 27, 2012, 10:53:51 AM »
I actually just ordered a set from apex. The person I talked to said the clamp height is 1.25" for the standard clip ons, 1.125" for the risers. I thought I saw a pic of someone's monster here that had the clip ons mounted above the triple.
seanster
« Reply #6 on: March 27, 2012, 11:19:30 AM »
you already ordered your but here is the link for the thread you should consider/checkout
http://www.ducatimonsterforum.org/index.php?topic=7724.0
suzyj
Does my bum look big on this?
« Reply #7 on: March 27, 2012, 11:37:32 AM »
That's pretty old - a lot of those clipons aren't readily available any more.
For the OP, I've got Woodcraft zero rise clipons above the triple  They're not quite as wide as your driven ones.  I had to drop the front end a few millimetres to make it work, but I reckon that's improved the handling of the bike.
JoeP
« Reply #8 on: March 30, 2012, 06:37:46 AM »
Thanks for all the help.  chug
Just sold my driven clip ons and my apex clip ons are getting delivered today.
sejman
« Reply #9 on: April 15, 2012, 08:12:45 AM »
How did the Apex clip-ons work out?
I have a '01 900S and I'm in the similar situation.  I have about 17mm above the top triple and only about 20mm below that is machined to 50mm diameter and then it starts to radius up to a larger diameter.  I am not sure if this is because I have an "S" version with the adjustable forks or what.  It seems like either way (above or below the triple) I will need to slide the forks up or down.  I'm leaning toward the Motowheels http://motowheels.com/i-6922767-mw-billet-clip-ons-w-risers-monster.html due to the narrow (19mm) mounting bracket and sliding my forks up 2-3mm and mounting them above the triple.  The Woodcraft and other riser clip-ons have wide brackets that would make me slide my fork tubes down significantly to make enough space below the triple and I don't think I want to change the geometry in that direction.
JoeP
« Reply #10 on: April 15, 2012, 07:21:08 PM »
They work well for me. The clamp height is 1.125 inches or 28.6mm and I mount them above the triple. The bike handles fine. They have the same clamp height as the clip-ons I had before which were silver Ducabike clip-ons like these:
