February 23, 2025, 12:02:46 AM *
Author Topic: flexible LED for backpack?  (Read 1472 times)
Privateer
« on: March 31, 2012, 11:37:31 AM »
I commute on my monster and almost always wear a backpack while doing so.  I want to make myself a little more visible to the Orange County texting-absorbed a-holes.
I wear this:
and was thinking I could insert some kind of LED tube in the MOLLE straps, powered by batteries.  I was imagining an upsidedown U with the ends in the far left/right straps, the U roughly following the contours of that pocket.
Unrelated, I'm also planning to add some reflective tape to my helmet, front and back.  Trying to address all angles of visibility that I can.
I thought it'd be pretty easy to find some kind of LED tube or flexible strip that would work but I can't seem to find anything online, any ideas?
S2R 800 '07
« Reply #1 on: March 31, 2012, 11:57:19 AM »
There are others, but this is one...
http://www.webbikeworld.com/r2/riderlight/
zooom
« Reply #2 on: March 31, 2012, 01:12:28 PM »
niteize.com has some adaptable things in their L.E.D. section....
2010 KTM 990 SM-T
« Reply #3 on: March 31, 2012, 04:32:52 PM »
You can just throw on a bicycle LED flasher.
Another option is to iron on some 3m reflective fabric.
Qfactor
Same shift, different gear.
« Reply #4 on: April 03, 2012, 07:02:58 AM »
I use a bicycle flasher light...
I haven't been rear ended.........yet
Q
Omnipotent Potentate
Personal Pretext
« Reply #5 on: April 03, 2012, 10:11:19 AM »
EL Wire
http://www.instructables.com/id/El-Wire-Backpack/
zooom
« Reply #6 on: April 03, 2012, 11:27:39 AM »
the problem I have with EL Wire is it disapears as soon as light hits it...it has a tendancy to be washed out practically...L.E.D. is less probelmatic in this regard from my experience due to the light output...
2010 KTM 990 SM-T
Grrrly
Industrial Grrrl
« Reply #7 on: April 03, 2012, 01:27:39 PM »
I have an older version of this:
http://www.niteize.com/collections/led/products/clip-on-marker
Lights up either a on steady or pulsing flash.
Grrrly
Industrial Grrrl
« Reply #8 on: April 03, 2012, 01:29:48 PM »
I also have a reflective safety triangle thingy that I clip to my pack as well.  I found it in a bicycle shop as well.
