What causes the clutch fluid to darken so rapidly?
Started by jgrm1, April 01, 2012, 02:52:24 PM
jgrm1
I changed all my fluids just a few weeks (500 miles) ago and the clutch fluid is already dark. In contrast, the brake fluid is still clear.  I've noticed this on other Ducatis.  What causes the clutch fluid to darken so rapidly?
-Jeff
BMW:  2016 R1200RS, 2000 R1100S, 1975 R90S
Ducati:  2008 S2R1000, 1998 900 Supersport Final Edition
Norton:  1974 Commando 850
Triumph:  2016 Thruxton R, 1971 T120R
ducatigirl100
I've just change mine a week ago because it was rally dark!! My firth though was that it was sitting in a humid garage for 6 month whitout moving
jgrm1
Quote from: ducpainter on April 01, 2012, 03:09:33 PM
The theory is it's engine heat.
I wondered about engine heat, but the brakes get pretty hot, too.
-Jeff
if you completely flush the circuit then it wont turn color as quickly.
it turns from a combination of moisture cooking and the seals rotting letting some oil in.
when i flush mine it lasts for a few months.  flush often and it will slow the process.
Quote from: ducatiz on April 01, 2012, 06:36:02 PM
All true...
but it will still darken faster than brakes.
Scissors
This isn't specific to our bikes.  Pretty much all cars which have clutch fluid also see it turn dark far more quickly than the brake fluid, and the temperature for both is about the same.  It isn't moisture either, since both systems have the same seals.
The real reason is that the rubber grommets/seals/o-rings (depending on the system) in a clutch piston move a far greater distance than the ones in a brake system.  The black rubber particles are therefore scraped off in greater numbers, darkening the fluid.
The brake system moves slightly, but is mainly transferring force as the pads don't move very far.  The clutch, in contrast, is transferring force, but over a greater distance as it disengages the clutch plates.
And now you know the rest of the story.
jgrm1
Quote from: Scissors on April 04, 2012, 08:03:07 AM
That makes sense.
-Jeff
I only use the clutch for starts.
It still gets black. :P
j/k...your explanation does make sense.
Would you look at the giant brain on this guy!  [beer]
sofadriver
ok, so how come my rear brake fluid gets dirty almost as fast as the clutch fluid?
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
If your rear brake lever is like mine, same reason mentioned above.
Longer shaft movement (giggity!) through a rubber boot (giggity?) each time you use it (that's what she said).
Seriously.
sofadriver
Mike in Tacoma
'96 900 SS/SP
IBA 38181
Scissors
Quote from: sofadriver on April 04, 2012, 08:12:18 PM
Magic.
Nottsbiker
Totally obvious now you have mentioned it! This bugs the hell outta me on my Tuono but at leats I've learnt how and why it happens.
Ducati Monster 900 (project) Aprilia Tuono 1000
