February 22, 2025, 11:44:24 PM *
Author Topic: Getting rid of the stupid stepper motor  (Read 1776 times)
korey
« on: April 02, 2012, 04:58:45 PM »
I've had tons of problems with my bike idling crappy. Surging up and down, stalling, etc. The TPS, CO, Fuel trim, TB sync, etc was all done and I still had the issue. So I decided to take off the stepper motor, since it's obviously the devil. Now, I have a DP Race ECU, so my results my be different from yours if you're all stock.
1. Get the bike up to temp fully
2. Go buy some vacuum plug caps in assorted sizes, autoparts stores all carry them
3. Disconnect the plug from the stepper motor, and remove the lines and cap off the plugs that they went to
4. Back out the air bleeds equally until the bike idles good by itself. 1/4 turn at a time. I had to back them out 1 1/4 turns
5. Go on eBay and buy a 748/996 throttle housing with the high idle button
6. Install the half of the housing, it swaps with the stock one
7. Adjust the cables slack so that the button works right
8. Enjoy!
My bike only requires you to have the fast idle on for about a minute, then I roll the throttle forward and is disengages it and idles fine. Here's a video
« Reply #1 on: April 02, 2012, 05:40:07 PM »
Would the idle lever from the S2R800 or smaller Monsters not work?
korey
« Reply #2 on: April 02, 2012, 05:57:46 PM »
No, the idle levers require you to have brackets on your throttle bodies. If your bike doesn't come with an idle lever, then you don't have the brackets. The 996 part works completely differently in that instead of having another cable run down to the throttle bodies, it just pushes on the regular throttle cam on your handlebar.
Roaduser
will be back on the road june 16
02 m800 with extras
« Reply #3 on: April 02, 2012, 06:33:50 PM »
i wonder if you can still use a g2 throttle tube with that.... is there any way someone can photo the oem throttle cam on one of these?
« Reply #4 on: April 02, 2012, 08:16:36 PM »
Ahhh, ok. I see. I haven't seen my bike in 2 years now...
Scissors
« Reply #5 on: April 05, 2012, 04:48:22 AM »
I always assumed this would throw a CEL.  So I guess it actually does not?
Bill in OKC
S4Rs
« Reply #6 on: April 05, 2012, 10:44:29 AM »
I did the same thing to my S4Rs w/DP ecu and no codes or lights - the power of hoping came through for me lol.
