Installing a Cycle Cat top triple & clip ons......how difficult?
Started by 118811, April 06, 2012, 08:37:16 PM
I searched but could not find any info on my particular situation.
I have a 98' M900, and just purchased a Cycle Cat top triple clamp & clip ons.
My question is how difficult of an install is this going to be?
I have a front yoke stand and tools.....my technical experience is limited though.
Thanks
corey
Quote from: 118811 on April 06, 2012, 08:37:16 PM
Thanks
not too hard, the difficult part is routing the brake lines, throttle cables, and stuff from the hand controls.
118811
Quote from: corey on April 11, 2012, 12:49:25 PM
Thats what I have read...but don't comprehend!?
Why do the cables need to be rerouted?
The only difference is now the bars are 2'' lower & maybe 1'' further away from the rider.
I guess I will see Friday morning...when I go at it!! [wine]
corey
Quote from: 118811 on April 11, 2012, 02:36:52 PM
note necessarily "RE"routed... just getting them on to the clipons and getting everything routed properly and at the right angles, etc... can sometimes be a big PITA. you'll be fine though, just be patient. also, what brand/type of clipons did you get? As most of them have aluminum brackets and stainless steel hardware, be sure to use some anti-sieze on the bolt threads to keep things from galding up.
118811
Corey, don't know what brand of clip on I have here, but they were on this M900 before I bought it.
Triple & clip ons actually look much nicer than my pics indicate [beer]
Do you reccognize them?...Thanks for the tip on using anti-seize!
Quote from: 118811 on April 12, 2012, 10:37:36 AM
Those clip ons look exactly like what I have on my S2R1000. Got them socond hand so I can't tell you what brand they are...
Yup, simple, fairly aggressive depending on how you mount them and much lighter than the stoch bar and risers...
corey
YUM. those look sharp.
Like I said, just be patient and take your time. It's not a race (yet!)
Wish I could find a sharp top triple like that for my bike. My clearances are so tight with my clip-ons that I don't ever really feel like risking a swap at this point.
118811
Well
all is on and in place...I can't see any issues...new grips are on, should be dry for a morning ride [beer]
time for a beer & dip in the ocean; its 85 & humid here [thumbsup]
here it is
If those are the clip-ons that Rick had on the bike, they're from MotoWheels.
118811
Quote from: DRKWNG on April 15, 2012, 04:09:27 PM
Yep....these are those.  Thanks for the info!! [thumbsup]
corey
The look like they may be "out" a little far. How's the leverage? Are your elbows able to be bent and relaxed while riding? I had mine set up like that for a while myself, then rotated them toward the tank a good bit and found it SO much better. You can slide a piece of paper in between my hand controls and my tank at full lock.
118811
Corey,
I might try that ....right now my wrists ache after 15 miles!!
I am thinking about possibly getting or making taller risers if my wrists don't adapt!!!
Just got home and moved them back some, as you suggested...about an 1'' from tank at lock.
Short spin around the neighborhood felt much better on my wrists. [bow_down]
The new position feels like I would have less control over the bike....I guess I will get used to it
