April 25, 2024, 11:30:17 AM
THCM
where do you keep your inspection sticker?
Topic: where do you keep your inspection sticker? (Read 5579 times)
seanster
Wat???? Hero Member!?!?
April 12, 2012, 05:13:50 AM »
I wanting to relocate my license plate under the seat, but don't know where would/should place my inspection sticker
bike is 2000 M750.
Suggestions that wouldn't get me in trouble?
wasabi
Re: where do you keep your inspection sticker?
April 13, 2012, 01:33:26 PM »
Still have not performed a tail chop yet. Just can't bring myself to cut the frame. Plus, now that I have high mount termi's I think the termis look a little odd sticking out past the tail. So I have the inspections sticker on the plate. and the registration sticker right above it.
Wasabi
'07 695 Monster
"The life of a repo man is always intense"
seanster
April 16, 2012, 05:55:43 AM »
Quote from: wasabi on April 13, 2012, 01:33:26 PM
Wasabi
how do you place the inspection sticker "on the plate"? isn't it too big to be on the plate? I do have the registration sticker on the plate but the inspection sticker on a separte metal plate (not license plate) below the license plate.
Sean.
wasabi
April 17, 2012, 10:28:40 AM »
Sorry I meant Registration on the plate and inspection right below it on a separate plate that is behind the license plate also.
Wasabi
'07 695 Monster
derby
June 13, 2012, 04:47:58 AM »
i'm sure you've found an answer to this by now, but you need a plate like this:
http://www.phatperformanceparts.com/Chris_Products_Inspection_Sticker_Plate_p/ch0620.htm
these are available from af1-racing in downtown austin for ~$6.
-- derby
'07 Suz GSX-R750
click
here
for info about my avatar
Pedro-bot
June 15, 2012, 03:44:29 PM »
I took a piece of hard plastic that I cut just slightly larger than the inspection sticker and bolted it to the right edge of the plate holder. If you look at the picture above just imagine cutting the lower section off then pivot it so that it sits on the right lateral edge with the narrow portion of the tab away from the license plate holder.
The tab is only bolted down using the top right hand corner bolt so the plastic holding the inspection sticker can be rotated behind the license plate, hiding it if desired.
I'll try to take a pic so you can see what I'm referring to.
Pedro-bot
June 15, 2012, 03:46:12 PM »
Quote from: derby on June 13, 2012, 04:47:58 AM
Do you live in Austin or are you very familiar with it?
For some reason I always thought you were part of the West Coast guys in Cali.
seanster
June 15, 2012, 04:03:26 PM »
I had that plate....
I guess my question was where do you keep your inspection sticker when you have hidden your plate under the seat, near the sock?
Here is the side view of my plate hidden (kinda like stealth kit from motodynamic) Where do you keep your sticker then? I saw some make a bracket large enough to mount to the swingarm and some just stick it to the swingarm. I'm currently have my sticker under the seat (where the tool bag is haha
thanks!
Pedro-bot
June 15, 2012, 04:11:26 PM »
Do you have a pic of your plate mounted?
It would give folks a better idea to see what you have to start with.
****BUT, I'm sure you can mount it like I have mine, regardless of where on your bike the plate is located.
Last Edit: June 17, 2012, 07:28:59 AM by Pedro-bot
hcomp
All this time I wondered what it was like to have a
Nothing to see here
June 17, 2012, 04:53:26 PM »
Quote from: Pedro-bot on June 15, 2012, 04:11:26 PM
Pedro, does that actually fly? You don't get stopped by running it 90 degrees to the plate? If that is the case, I'm going with your mount system. Also, do you have to have rear reflectors?
Last Edit: June 17, 2012, 05:23:31 PM by ryanracer
にもかかわらず、私の車は本当に速いドライブ、私は女性の生殖器のようなバイクに乗る
seanster
June 17, 2012, 05:29:44 PM »
Pedro-bot
June 18, 2012, 05:05:52 PM »
Quote from: ryanracer on June 17, 2012, 04:53:26 PM
I have never **knocks on wood** had a problem with this. It's how I also have it mounted on my S4, now over 5 years.
IMO it's not any different than mounting it on the swingarm. It's visible, thats all that counts.
I have never heard of reflectors being mandatory anywhere on the motorcycle. From what I understand, to pass inspection in Texas all you need is a brake light and headlight. You don't need the signals, but if you do have them they need to work.
Quote from: seanster on June 17, 2012, 05:29:44 PM
Why not mount at the base of the plate, just below it? Make a small plate holder out of a thin hard plastic.
Last Edit: June 18, 2012, 05:09:54 PM by Pedro-bot
