CAM & BAD track day?
Started by Meerkat, April 12, 2012, 04:12:36 PM
zooom
Quote from: Slide Panda on June 28, 2012, 03:35:30 AM
Secondary issue is the asking price.
for THAT bike...that isn't an unreasonable asking price at all...
that being said...what SP said about the cost to repair that bike in the event of a crash isn't incorrect at all...but it'd be a hoot and a half to rock that thing around the track with the flatsides and all...it makes a great honker of sound from the intake alone when you twist the throttle coming out of a turn...and I bet it is a pretty damn light machine all said and done with those mag wheels and all....only thing I'd change on it would be to upgrade the brake master and possibly the calipers, but not an immediate extremely needed upgrade.
2010 KTM 990 SM-T
yeah I didn't put it quite as clearly as needed - in a rush then.
For a first track bike there are potentially better values out there. A track SV 650 with some farkles or even (Jebus forbid) some ilk of i4 could be had for less. had the piss ridden out of them by you and sold off again for about what it was purchased for. Of course the SV is no Bimota... but it doesn't suffer from the same price penalty for any fixes or even (probably) mods.
If you're serious about hunting down a track ride, I'l start patrolling the CSS and WERA forums
http://www.ccsforum.com/index.php?PHPSESSID=bd97250e70b800263782b3792644aa02;wwwRedirect
http://forums.13x.com/forumdisplay.php?forumid=12
and possibly DCSportbikes.net
tocino
Ditto. If it's a 900/944 flatslide bike you want for, there are a lot of SuperSports around. And as pointed out, fixing crash repair won't be easy / cheap. Also, I've seen the bike in person and thought it looked better in pics (ymmv).
A 600cc Yamkawaski is your best bet. 6yo ex-racebikes can often = cheap with lots of good bits. If you like the idea of lightweight bikes, there are tons of SV650s out there.
Quote from: tocino on June 28, 2012, 06:06:06 AM
Good point. And being Bimota it'd be most costy than a Duc to fix (probably). There's also Injected 800 and 1000 supersports floating around if you really want a 2v air cooled twin.
ducFrank
Not specifically targeting this bike/brand/engine... just what duc pond has on the rack.
I found an 05 R6 for $2k - track only... kinda like the thought of the R1 to grow to but... $2k.
2005 Ducati 749S track only
2009 Ducati 1100S - bent frame
Sure it's not an R3? 2k seems like it might only be half a bike...
tocino
Quote from: ducFrank on June 28, 2012, 08:06:53 AM
link?
http://washingtondc.craigslist.org/mld/mcy/3093288663.html
I'd have it checked out at a shop to be sure - but looks solid enough.
ducFrank
Meerkat
'07 S2R1K
'09 Daytona 675
'03 620 Dark-Sold 03/26/2011
And a shrubbery!
Read up on the RC 51.. might put you off
ducFrank
Meerkat
http://weraclassifieds.com/ads/2005-yamaha-r6-track-weapon/ track prepped (NO TITLE) motorcycle with 2459 miles.
Here is the list of goodies:
Race Tech front fork internals (rebound/compression valves) set up for 170 lbs.
Ohlins 3-way adjustable rear shock set up for 170 lbs.
**Both of these were built 3 trackdays ago**
Harris adjustable steering damper
FULL Hindle exhaust system
BMC RACE air filter
Dynojet Powercommander USB
Vortex frame sliders/clip-ons/rearsets â€" GP shifting
ASV folding brake/clutch levers
Goodridge stainless steel brake lines up front
Vesrah “white” race pads up front â€" same ones Ben Spies/Mat Miladin used on their superbikes.
Air Tech bodywork in good condition with a new zero-gravity double-bubble windscreen
Set of race stands
Set of Tire SOX tire warmers
Distilled water with water-wetter
Safety wired
Extras:
Set of wheels with used rain tires mounted
Set of Vortex bar-ends (for when the opps happens)
Set of OEM brake/clutch levers
Full Yosh exhaust â€" crashed but usable
'07 S2R1K
'09 Daytona 675
tocino
That's a lot of goodies! But no title, not even a salvage? That would make it a no for me. Not that I've ever been asked to show proof of ownership on a track bike.
On the RC51 I'd say no.
There's a couple current track bike listings with no titles... that weirds me out too. No reg... yeah sure makes sense for a track bike. But no title? Sets off my sketch alarms. It's not some 50 cc dirt bike
