how do turbo cars work in Reverse?
Started by acalles, June 24, 2008, 05:34:46 PM
Randimus Maximus
sno_duc
 [laugh] [laugh] [laugh]
Somewhere in the old country a village is missing their idiot.
A conclusion is the place you got tired of thinking
Kaveh
I've seen a 4.2l jeep motor run in reverse.  The owner put a F.I. conversion kit on it (which is bad-ass BTW) but old Harmonic Balancer. I forgot which order it went, but the either the F.I. harmonic balancer or the Carb Harmonic balancer has waaaay more notches in it for the computer to read to determine rpms.
When homeboy went to fire it up, it barely started and then stopped and went into full reverse.  Exhaust was shooting out of the intake!  He was thinking really quick because he ran to the rear of the car and stuffed a bunch of shop rags into the tailpipe to shut off the air intake and turn off the motor! [laugh]
Vindingo
this is almost as good as the M3 guy who got a sock tangled inside the motor!
OK, there is NO WAY that guy is serious!
Scottish
Le Pirate
teddy037.2
Quotegeez, you guys post quickly, I was busy running an experiment to try to figure this out for myself
I was thinking "how can you prove that the engine is running backwards" when it hit me, I can use a balloon. So I got a balloon and put it around the exhaust tip. I figured when I start the car it will inflate, but when I put it in reverse it will suck the air and balloon back in. So I started the car up and went in reverse about 10 feet then turned the car off. I went and checked the tail pipe and sure enough there was no balloon, it got sucked inside the tail pipe. So I got back in the car, started it up and drove forward about 5 feet. I got out and looked on the ground and the balloon was right behind the tip. So when I pulled forward it shot the balloon that was in the exhaust back out and thats why it was on the ground.
So yea, engine runs in reverse in reverse, now I just need to do it again and see if I get full boost.
I had no idea! turns out the boy was right!  :D
Ducatiloo
 [laugh]  sucks all the air out of cylinder
750 SS 01    800 S2R 05  Aprilia RST 1000 futura
krolik
I got a tank engine, AVDS-1790 Turbo Deisel, to run backwards once.  It wasn't the same after that. 8)
CairnsDuc
Sounds like he needs another bag of Sand.......  ;D
Pedro-bot
Big Troubled Bear
