leaky faceshields
Started by sejman, April 18, 2012, 08:05:59 PM
sejman
Any tried and true fixes for air/wind leaks in faceshield?  I wear contacts and during rides in hot and dry Texas summers even a small amount of air leaking can cause uncomfortably dried out eyes after a while.  I figure some very thin/soft foam weatherstripping stuck on the inside of the faceshield where it mates with the helmet might work...
thought
Are you sure it's not the venting from the helmet?  Most helmets vent to the faceshield.
An interim solution if it's really causing you large issues is to wear sunglasses under your shield.  that will block the air directly hitting your face.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
My helmets allow me to adjust the shield for a tighter closed position.
If you don't have a good rubber lip, it might be time for a new helmet?
sejman
The problem doesn't seem to improve/worsen with the venting options open/closed. Both of my helmets have this issue. I guess I can experiment with some foam and see what happens. Maybe its time for laser eye correction ;D
Quote from: sejman on April 19, 2012, 04:45:41 AM
Brand and model helmet?
No helmet is sealed - are you using/do you have a chin curtain? IF not, a lot of air is blowing up from the opening. With, there will be some, but will be reduced.
Blackout
2003 Ducati Monster 1000
2003 Honda CR250
2008 KTM 990 SuperDuke
sejman
I have an AGV S-4 and a Sparx S-07.  Neither are high-end helmets.  I actually prefer the cheaper Sparx helmet...it fits my head better.  I'll try the chin skirt next, and make sure I keep contact lens drops with me...
thought
Did you try out wearing sunglasses yet?
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
sejman
No - I have a dark smoke shield on right now so that would make things too dark.  I can try that with a clear shield...
wannabfast
ya know, safety glasses work nice too, and you can get them clear... or amber, whichever you choose
Jdan
You might want to take a look at a new prescription and/or new brand of contacts, preferably soft. I had the same problem when I first started riding, and when I got a new prescription and new brand of contacts, the problem went away.
