No chop tail install
Started by Eldon, April 19, 2012, 05:51:46 AM
Eldon
Anyone install a no chop tail on a 2007 s4r. I am trying to do one and the tail light hits the seat from going on. Anybody run into this.
Thanks
Put a couple washers under the seat post to give you a bit more space.
Eldon
Thanks for the reply. Are talking about spacing the seat latch up with washers.
Thanks
I had the same issue.
Both metal parts mounts under the frame [thumbsup]
Either or both. You can add some washers under the post attached to the seat and under the latch mechanism on the frame.
Eldon
Thanks for all replies I will try it tonight.
