minor changes lead to dead spot off zero throttle?
Started by Raux, April 21, 2012, 04:09:02 AM
put the PCV on, and lighweight flywheel. valve job completed.
on zero throttle to about 5% there's a stuttering happening. seems a fueling issue.
didn't happen before the two changes even with the PCV's optimizer installed.
should I be looking at the PCV or a maybe an air leak intake/exhaust side?
While checking my work shop manual for other things, I noticed a remark about checking an air gap under a left side sensor connected to generator work. Absolutely no idea if that's relevant, but better to mention than not....
Quote from: stopintime on April 21, 2012, 05:41:09 AM
ok i will check the manual
well went in and adjusted idle screws. brought the resting idle when warm up to 1200.. problem gone.
