kick stand
Started by sofadriver, April 21, 2012, 09:14:38 PM
sofadriver
We finally had a nice day here today and I was reminded that I have to do something about the pad on the end of my kickstand. I ground half of it off when I low-sided last fall (S2r1000's slide along real nice on the front axle, left bar end weight and the kickstand pad  :'( ). The pad is now ground into a spearhead shape and will sink into hot asphalt for sure. Any ideas besides welding on a larger pad or carrying one of those plastic kickstand pads/ flattened soda can? Last time I removed a kickstand it was a real PITA.
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
zooom
2010 KTM 990 SM-T
sofadriver
Quote from: zooom on April 22, 2012, 01:31:21 AM
perhaps something like this?
http://www.twistedthrottle.com/trade/productview/6802/
Thanks, Zooom, but there's not enough pad area left to drill thru.
Looks like I'll have to have it welded.
Mike in Tacoma
'96 900 SS/SP
IBA 38181
xcaptainxbloodx
if you remove the sidestand switch you can use one from a hypermotard or Multi 1100.
I didn't care enough to put energy into figuring out what part of the switch you would need to re-work to keep it, but the problem with it is that its reversed (so the bike shuts off with the sidestand up and in gear)
