January 06, 2025, 07:31:53 PM
Please Help
hardware store o-rings..
Topic: hardware store o-rings.. (Read 1940 times)
aaronb
June 24, 2008, 06:28:40 PM »
incredibly stupid question, but what are they made from? you know the shiny black type.
i accidentally damaged one of the two on one of my fuel line fittings this weekend which resulted in a tiny stream of gas pissing on the exhaust from the vertical cylinder. good thing i noticed it right away after starting the bike this morning. so i found the sliced o-ring on the fuel line fitting, and got a replacement from the hardware store up the road. no mention on the drawer what they were made from (Buna-N, Viton, etc). it is currently working just fine, but should i replace it with one from the dealer ASAP? the original was also black but felt a bit softer.
I asked the guy at the hardware store what they were made of and in a dead straight face he said 'rubber, primarily' i don't know if he was being an ass or was just completely stupid
Last Edit: June 24, 2008, 06:37:53 PM by aaronb
Milwaukee, WI
'07 s2r1k, '81 honda cb400t
Re: hardware store o-rings..
June 24, 2008, 07:19:51 PM »
No way of knowing, black O rings may or may not be gasoline compatible.
Langanobob
June 24, 2008, 08:56:42 PM »
Aaron,
The standard o-rings from hardware stores are usually buna-n, which is compatible with gasoline. But, I don't know of a way of telling for sure, so it wouldn't hurt to get a real one next time you're near a dealer.
June 24, 2008, 09:40:29 PM »
You could always buy another one and soak it in gasoline. See if it breaks down...
June 25, 2008, 06:30:45 AM »
i have a supplier who sells all kinds of o-rings (and z-rings, x-rings, quad-rings) in buna, nitrile, EPDM and a bunch of other exotic stuff.
i can post their info when i get home, they are a big company but will sell small quantities. they have plenty of metric stuff too.
i got Z-ring seals for an older Pantah clutch (of course, no long available) and they matched it perfectly. the EPDM material is far superior to the natural rubber and is DOT 3,4,5 compatible.
hypurone
June 25, 2008, 06:48:53 AM »
Quote from: ducatizzzz on June 25, 2008, 06:30:45 AM
Now that right there is pure porn for a gearhead!!
aaronb
June 25, 2008, 09:38:50 AM »
i have to run to the dealer soon to pick up an oil filter, i'll just get a new o-ring or maybe even an entire fitting then. it wouldn't hurt having a spare fitting in the box, im always worried i am going to break those thin plastic sides when squeezing them.
i think the hardware store o-ring will be fine but if it should fail in the future it will leak fuel onto the exhaust. i don't think 50 cents is worth risking the entire bike over.
Last Edit: June 25, 2008, 09:41:38 AM by aaronb
Milwaukee, WI
