Clutch Cover????
Started by udiaz27, April 24, 2012, 02:04:15 PM
udiaz27
What kind of clutch cover can i get for my ducati monster, it is a 2012 monster 1100evo, and i can't seem to find anyones that are compatible with my model. how do clutch covers work, do i just remove the original cover and put the new one, or do i need some other parts? thanks.
lazylightnin717
I think the new 1100 EVO motor uses a wet clutch
Not sure what is available for the wet clutch Ducatis
Maybe I'm being captain obvious or maybe I'm at least being a little bit helpful?
Comes a time
Says don't you see
Gotta' make it somehow
Kopfjager
As stated above, your bike has a wet clutch so you don't have many if any options. I'm sure speedymoto will come out with something, but nothing along the lines of the dry clutch motors.
udiaz27
Thanks you guys, I guess I'll stop searching.
There's a couple covers that you bolt over the engine accessory case for the wet clutch bikes. But the selection is limited in comparison to the offerings for the Dry clutch bikes.
And there's no open options of course.
lazylightnin717
Don't stop searching
If anything, voice your opinion to companies to make clutch covers for the new gen. Monsters
I'm sure you aren't the only one looking
Comes a time
Says don't you see
Kopfjager
Speedymoto did these for the other wet clutch bikes, so I'm sure they'll be doing one for the 1100.
http://www.speedymoto.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=WET
monster 795
R & G Racing makes covers that I haven't seen much of around.
http://www.rg-racing.com/
duccarlos
I was going to suggest the transparent wet clutch covers.
cayman s
Quote from: monster 795 on July 21, 2014, 12:46:28 PM
The R&G cover is designed to fit on top of/over the factory clutch cover.  Think of it as a clutch slider.
