m1100 2009 clutch job?
Started by polivo, April 25, 2012, 04:44:48 PM
polivo
Guys, just looking for baseline. Whats an average price to replace to clutch on 2009 ducati monster 1100? Im getting mine done soon, and I just want to have some idea before i go in!  Thank you.
I cant answer your question, sorry.
Instead, I have a question for you:  What the issue with the clutch causing you to need to have it "done"?
Cheers,
Ung.
polivo
its starting to slip.  Im not handy , so i took it to a ducti shop and they said it should be replaced.  Theyre charging me about 560.00. Is that about average?
Not enough info.  Are they changing all the plates?  Just the friction plates?  Basket?  Who's parts are they using?  Did they explain to yopu why it is slippng?  Also, did they check free play at the lever?
polivo
Sorry guys, im  a total noob at this stuff. Thats why i took it to the dealer.  All they said was the "clutch pack" was going to cost 370.. and 2 hours of labor at 80 dollars?  I assume they checked for loose cables and stuff. I dont know.
Nothing to be sorry about.   IMO, 2 hours labor is a bit much for a dry clutch and the price is about right for an OEM clutch pack.  It is an estimate, so maybe they are just leaving a little room.
polivo
Thanks, i feel better. Thought i was getting raked.
Dry clutch pack is about $280 retail, at least here in the States.
Shouldn't take more than an hour to swap the pack.
Quote from: polivo on April 26, 2012, 05:30:13 AM
How many miles/kilometres has your M1100 done?  Reason for my interest is that the clutch on my M1100 seems to be on the verge of letting go too.
Enzoman
My 09 M1100 has about 5500 miles on it and the clutch doesn't seem right, like it's slipping and doesn't grab like it used to. I heard some noises from it when leaving a stop light a few weeks ago and stopped riding it. Is this normal mileage for a dry clutch to start to go? What are the symptoms?
Dellikose
That seems really soon for a pack to start going. I take it they were the OEM plates to begin with?
1999 Ducati M900
18,000 Kms on my 09 M1100, the clutch isnt yet slipping but it now only bites at the very end of its travel (and I know late engagement is a Ducati dry clutch idiosyncrasy, but this is a recent deterioration and not what I've been used to during the first 17,500 kms).
Original stock clutch pack (aftermarket pressure plate).
Enzoman
Original plates with DP pressure plate and aftermarket springs. I don't remember where I bought the springs, but I think they came from Motowheels.
OEM packs an last from 5,000 miles to over 30,000 miles. just depends on who the user is.
Mine is on average 10,000-15,000 but that is HEAVY city miles and some not so nice clutch work (burn outs, track days, hard take offs) all those things add up to the wear of the clutch pack. IMHO, buy it yourself and swap it yourself its as easy as 3 bolts and some hooks.
if you have a lot of time and miles on it, the basket may need replacement too, if thats the case then you will need additional tools, some of which are not worth buying unless you are going to be using them often enough.
Dellikose
If you mean the tool to hold the basket/hub check this one out: http://bit.ly/JBQ4mf
It's $25 shipped. I just used it (literally 20 minutes ago) and it worked great. You can hold both the hub and basket, though you have to remove and reinstall between the hub and basket...it's just 2 bolts though.
1999 Ducati M900
