April 25, 2024, 09:08:58 PM *
Author Topic: cracked instrument bezel  (Read 1174 times)
Armor
« on: April 26, 2012, 03:53:48 PM »
I have no idea how it cracked, but I now have a crack in my tach and speedometer lens.  Searching, it looks like my only solution is to find a used cluster and transfer the front plate with the lenses.  Is there any other way to fix?  It almost looks like something hit the gauges (when parked?).  I noticed the cracks when riding home from work.
Nomad
« Reply #1 on: April 26, 2012, 05:01:07 PM »
Good luck, i tried forever to find a new bezel for my cool roadracing tach, they are the same size as the DP ones, but I don't think even trying to transfer those bezels would work.  You pretty much have to just buy a new gauge, unless someone says differently.  They are screwed then glued on, so trying to get them off is likely to break them.
Silver King
« Reply #2 on: April 27, 2012, 01:54:16 PM »
Yup.  You pretty much have to find a used one to do it right.  I had marginal luck by taking everything apart, removing the broken bits, dremeled out the crap, and glued in a piece of clear lexan that I cut with a hole saw.  If you're close to the bike you can tell something's off.  Otherwise, it does its job.  Besides, I never look at my speedo anyway.   Evil
ute
I Have Titanium
« Reply #3 on: April 27, 2012, 03:48:14 PM »
Here's a great link to help you
http://www.ukmonster.co.uk/monster/showthread.php?t=20161&highlight=cracked
sl8tr
« Reply #4 on: April 28, 2012, 08:46:06 AM »
I just used a strip off my iphone screen protectors. Can hardly see it and it keeps the rain out.
Pedro-bot
« Reply #5 on: April 28, 2012, 10:22:58 AM »
Remove the lenses, see the link above, and take them to a local plastics company. You can inquire in advance if they sell plexiglass. They should be able to cut the plexisheet to duplicate your lenses.
