{fixed} Tigre face to face with the next step
Started by Desmostro, April 28, 2012, 08:09:49 AM
desmoquattro
My Vices
'09 KTM 690 SMC (Thumpy)
'05 MS4R, blue
Spidey
tigre
'12 1199RS Tigre 6
'12 1198RS Tigre 7
'00 M944S Tigre 1
AFM #5 - Open Twins and more
DanTheMan
Quote from: tigre on May 10, 2012, 11:28:49 AM
Plan is to leave mostly stock.
Except pistons, cams, decking the heads to boost compression, adding nitrous system, etc.
No smiely for this. <FACE PALM> smack!!!
How about this give me 20,000, I kick you in the balls and you leave it stock. Probably the same feeling if you do all the work and broken motors.
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 M630ie Dark - Sold
2003 CRF175F
1996 Honda CR125R - Sold
tigre
I'm going to leave the motor alone.  I will get an exhaust -- possibly the termi system that unlocks shit in the ECU.  I may run race gas if I can figure out how to map it....  That's it for motor.
'12 1199RS Tigre 6
'12 1198RS Tigre 7
'00 M944S Tigre 1
DanTheMan
Dude I'm totally joking. Deck the heads cross cut gears bore it Out marchisine wheels cams 5 angle grind. You'll never win unless you do
It.
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 CRF175F
Spidey
Make sure you save down the cases right around the crank to save weight.   [thumbsup]  If you can get 'em down to 2-3mm thickness, you're golden.  When you're done, you should be able to fold 'em like tin foil.  Then you know you've got a winning bike.
;D
desmoquattro
And let's not forget to route the front brake line under the fender.
My Vices
'05 MS4R, blue
tigre
Yeah... sticking with the stock fender for right now...
Quote from: desmoquattro on May 11, 2012, 10:06:40 AM
'12 1199RS Tigre 6
'12 1198RS Tigre 7
'00 M944S Tigre 1
DanTheMan
Quote from: tigre on May 11, 2012, 08:32:55 PM
Make sure there is room for the phantom DVD
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 CRF175F
