Rotors ...
Started by INFIDEL, May 04, 2012, 08:45:59 PM
INFIDEL
Anyone got spares lying around you'd like to sell?
Looks like I need to replace all of them front and rear and boy howdy are new ones expensive
Help save a child: http://www.firstgiving.com/318
Twitter: http://twitter.com/318FORKIDS
scott_araujo
Warped or just worn?
Scott
INFIDEL
scott_araujo
I got no tricks to fix that :(
ryandalling
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
scott_araujo
Careful, lots of ridersr warp their stock rotors, buy an upgrade, then dump the warped stockers on eBay.
Scott
INFIDEL
Didn't you kind of imply below that you had a cure for warped?  [bow_down]
Plumbers Crack
I just dropped 550 on galfers.  I should have them installed this week..  Ill have Duck Stew take a look at my 320's when they come off..
Sorry I don't have a censor button.. I Speak whats on my mind.
scott_araujo
Quote from: INFIDEL on May 09, 2012, 06:44:54 AM
Cure for "apparent" warp.  Sometimes a bike will pulse the lever like crazy making you think the rotor is warped.  It's often dirty button and/or a bad layer of brake material on the rotor.  Clean the buttons and lube them just a tiny bit so the rotor can float properly and then scrub the ever loving crap out of the rotor with brake cleaner and a genuine ScotchBrite green pad to get the old, uneven brake material off the disc.  Then suff up your pads and do a series of 10 hard stops from high speed with cooling between.  This lays down a new, even layer of brake material on the disc and beds in the pads.
I wouldn't believe this would work but my bike shuddered like crazy when I got it, I swore I needed new rotors.  I did this and it was silk smooth.
You can also beat down the button springs and make full floating rotors but that's a more aggressive strategy.
Scott
INFIDEL
Quote from: Plumbers Crack on May 09, 2012, 07:43:04 AM
Sweet.  Thanks.
