November 25, 2024, 03:18:05 PM
Where to mount GPS
Topic: Where to mount GPS (Read 1512 times)
mysticbluex3
Where to mount GPS
May 07, 2012, 10:23:42 AM »
I have a M696. I'm looking to set up a Garmin car GPS to it. Has anyone set up a GPS to their Monster? Where/how did you mount it? Did you wire it to your battery? I'm not very electrical, do I need to wire a fuse inline to it? Or should I just wire a cigarette adapter to the battery to plug the GPS into?
CDawg
S4RS
Re: Where to mount GPS
May 07, 2012, 10:39:18 AM »
I mounted mine in front of the of the instrument cluster; above the steering damper.
I wired mine into the headlight harness, but you can also use the battery tender pig-tail.
seanster
Wat???? Hero Member!?!?
May 07, 2012, 10:59:07 AM »
Quote from: mysticbluex3 on May 07, 2012, 10:23:42 AM
http://www.webbikeworld.com/r4/waterproof-motorcycle-usb-port/
if you have the stock upper triple then you should consider this also:
http://www.ram-mount.com/NewProducts/MotorcycleClampMount/tabid/2038/Default.aspx
Answer to your wiring question:
http://www.ducatimonsterforum.org/index.php?topic=50776.0
Last Edit: May 07, 2012, 11:01:10 AM by seanster
supertjeduc
May 07, 2012, 12:52:48 PM »
Is an old TomTom but it does the job
seanster
May 07, 2012, 01:14:21 PM »
can you snap a pic from the back of the mount? it's the tank mount correct?
I'm interested in this one too.
tom_sd
May 07, 2012, 01:25:11 PM »
I've been searching through the archives for the same info. I've read references to a mount that uses the stock mirror mounts, but haven't been able to find any photos or a place to buy.
supertjeduc
May 07, 2012, 01:37:41 PM »
