January 09, 2025, 11:32:10 AM *
Author Topic: Ducati 696 - Race/DP ECU Revlimiter?  (Read 1014 times)
metroplex
« on: May 08, 2012, 01:52:08 AM »
Has anyone confirmed the revlimiter setting for the Race/DP ECU? It seems to cutoff at 9700 RPM for me. I thought someone said it should be above 10k RPM.
These aren't the droids you're looking for
« Reply #1 on: May 09, 2012, 11:50:13 PM »
someone mentioned different limits per gear. have you checked that?
metroplex
« Reply #2 on: May 10, 2012, 12:33:44 AM »
I've only checked in 1st gear.
« Reply #3 on: May 10, 2012, 01:21:38 AM »
yeah i heard first was lower.
i run out of room to check 6th  Wink
metroplex
« Reply #4 on: May 10, 2012, 01:26:19 AM »
I made a spreadsheet using the factory gearing and tire size, and based on my Ducati data acquisition readings, it's almost spot-on.
I heard the 696 doesn't have enough power to overcome its aero drag, so the top speed is somewhere around 130 mph. In 6th gear, that's just under 9000 RPM?
« Reply #5 on: May 10, 2012, 01:26:54 AM »
hmmm.
