November 25, 2024, 05:33:13 PM *
Author Topic: 848 to m696 fork swap axle/rotor spacer source  (Read 1326 times)
Utekineir
« on: May 08, 2012, 09:38:03 AM »
Hi,
Have read the threads on the swap.
Is there a vendor out there that has made/will make the spacers for front rotors and axle?
Or does anyone have the specs for the rotor spacers?
Thanks,
Link
« Reply #1 on: May 08, 2012, 10:48:51 AM »
Hi,
Thanks,
You can buy 2.5mm brembo spacers from AF1 racing in Texas, you would need 4 of these your looking at 5mm offset for each rotor. Or you can have some made. But instead of spending money on spacers spend about another $300.00 and get some Galfer rotors with the correct 15mm offset and you will loose 2lbs of weight from your front wheel plus you get great looking rotors.
Utekineir
« Reply #2 on: May 08, 2012, 11:01:24 AM »
Thanks for info.
Having a bit of trouble finding the gaffers in a set for $300 though looking closer to $250-300 each.
http://www.af1racing.com/store/Scripts/prodView.asp?idproduct=2421
These should be the spacers mentioned.  Honestly think i'd rather that route since it would retain easy rotor replacement down the road.
Was leaning toward changing the bike till i pulled up the ins premium change from m696 to an 848 or panigale.  1 year worth of the premium increase i could rework the 696 to be perfect for my uses....   30 with a clean record, 400ish a year to 2400 range progressive was quoting me.  F that, killed my sbk itch real quick.
« Last Edit: May 08, 2012, 11:16:08 AM by Utekineir » Logged
696
Link
« Reply #3 on: May 08, 2012, 11:53:35 AM »
Thanks for info.
I was figuring your gonna spend about 100-150 on those shims so another 300 would get you to about 450. If you wanna save some coin source some 5mm or 4.5mm aluminum stock and make your own, there real simple to do I did 2 and they came out pretty good.. too bad I threw them away or I'd let you have em.......trust me though the wave rotors make a significant change in the bikes steering and it's all good ! I've seen guys spend 1.5K on a carbon wheel for about the same weight savings. Good luck with nyour mod post up results when done.
Utekineir
« Reply #4 on: May 08, 2012, 12:14:10 PM »
Maybe i'll experiment with making some up,
Have a drill press here, i've redrilled auto rotors for a different bolt pattern with good success before.  I was worried about having the spacers drilled properly not to be off center weight wise.  Figure theres a lot less forgiveness with a motorcycle rotor than an automotive rotor.
