Help Glady Appreciated!
Started by AudiFan, May 10, 2012, 10:16:12 AM
AudiFan
Hey there fellow Duc riders i would love to have some help (use your tool and your expertise) with syncing the throttle body on my S4R.  I feel as if this is the issue since at idle my Duc stalls.  Payment for your time, advice, tool usage, and company will be made for sure.  Beer or Cash just let me know. [thumbsup]
MikeZ
Might want to mention what area you're in or able to travel too.
JoeP
Have you tried just turning the idle screw up or checking that the mixture screws are backed out to about the same amount? Also check valve clearances. I'd do this before messing with the sync. Anyways, I'm in the same boat as you and was planning to build a homemade sync gauge this weekend (a very high-tech gadget consisting of a plastic tube and some used motor oil). If it works you're welcome to use it. BTW, I've never synced carbs before, just thought you should know.
AudiFan
I actually have not attempted to adjust the mixture nor idle screws good idea tho.
I am in NOVA but i am will to ride out since i am asking for help i wouldnt want to turn my nose up on help due to distance.
tocino
To ask a question that will show my ignorance re: S4Rs - is that a fuel injected bike (you say "throttle bodies" and not "carbs"). If it is, is there not a method for resettng the TPS auto-magically?
AudiFan
yes its fuel injected which is why i did say throttle bodies but i do not know of some way for reseting it
Quote from: AudiFan on May 11, 2012, 04:41:18 PM
Easy.  Throw money at it.
JoeP
Oops, I didn't catch the FI part. Guess I have carbs on the brain and can't see anything else. Moving along....
AudiFan
i adjusted the idle screw and boom idle is at 1500 rpm it no longer stalls but i still would like to get it checked out.  What shops do you guys use out here?
Zulu
I have used ducpond and coleman's at falls church in the past.
I been happier with Coleman's at falls church.
10' M696
