streetfighter front end
Started by wannabfast, May 10, 2012, 09:16:46 PM
wannabfast
i got a 796 and i sort of want to swap my front end(headlights gauges, bars, forks) from a streetfighter
now, does anyone know the pinout on the gauges from the streetfighter? i like how everything is integrated
anyhoo, i figure at minimum the upper triple, lower triple, headlight and gauges, but im not sure if the gauges will plug into the monster harness
gatorgrizz27
Gauges are never going to work.  Its not just wiring them in, aside from the immobilizer issue the streetfighter dash has its own integrated ECM which runs all of the functions controlled by the handlebar switches.  In addition the speedo and such as well as many of the engine sensors tie into the dash before running to the ECU.  I have completed a lot of projects that people have said were too difficult or not worth it but that dash swap is much more than just re-wiring it.
Headlight should be easy enough though  [thumbsup]
wannabfast
well the issue is that the streetfighter gauges are attached to the headlight
Quote from: wannabfast on May 18, 2012, 10:45:55 PM
from what gatorgrizz27 had to say, I'm thinking the issue is that..... its never gonna work.
wannabfast
well i suppose i would probably have to get something fabbed up to fit if i chose to go that route [bang]
