January 26, 2025, 01:03:19 PM *
Author Topic: REgulator instalation  (Read 1090 times)
ducatigirl100
« on: May 11, 2012, 12:50:46 PM »
Hi  Smiley
I  got a new regulator from Ca Cycleworks http://www.ca-cycleworks.com/products/electrical/esr515
I was wandering if the yellow cables ( in Haynes manual) that go to the alternator have to go in a certain order or it donsent matter ? Because it's hard to figure them apart ( both being yellow) ...there's no indication on the regulator to figure them appart
I got a 1995 900cc Monster
Online Online
« Reply #1 on: May 11, 2012, 01:12:22 PM »
It doesn't matter.
Just make sure those connections are good. Many people have had those connectors melt from bad connections.
ducatigirl100
« Reply #2 on: May 11, 2012, 01:24:44 PM »
Tanks waytogo I'll be meticulous whit the connectors Grin
battlecry
On a silver black phantom bike...
« Reply #3 on: May 11, 2012, 02:06:49 PM »
dg, corrosion is part of the problem.  It raises the resistance of the terminal contacts and burns current as heat, melting the connector.  Any chance you can buy a small quantity of terminal grease?  It is called dielectric grease or silicone grease.  You should coat the terminals to protect them from corrosion if you can.
ducatigirl100
« Reply #4 on: May 11, 2012, 04:25:22 PM »
I think I have some leftover from when I changed all my starter wire but I know what it is ...tanks for the tip,  I haven't tough of that waytogo
