Stubby exhaust? anyone used one of these??
Started by RRossi, May 12, 2012, 10:33:42 PM
RRossi
Looking to do somthing with my stock cored cans as I need a change and want to clean the look up on my m1000,
was thinking these but am unsure?
http://www.ebay.com.au/itm/170690126847?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
if anyone has any thoughts I would love to hear from you :)
RR
seanster
Was thinking about to but others convinced me not to go that route
Timmy Tucker
Quote from: seanster on May 12, 2012, 10:36:31 PM
I'm interested in these as well. What was the reason you didn't go with 'em?
1999 M750 - "Piggy"
2007 S4RS
seanster
Quote from: Timmy Tucker on May 13, 2012, 07:08:09 AM
first off it was the noise level...but I have D&D, so not much of a difference.
Others telling me that it similar to you just taking off your mufflers and run straight pipe, which in turn not good for your engine due to pressure and lost of power...I'm not exhaust guru or expert, but it make sense when think of it.
I'm still waiting for someone with experience with this that convince me to go with this stubby.
wannabfast
i wouldnt pay that much for $15 worth of exhaust piping you can get at the local car parts store...
might as well run open pipes
however running open pipes you can potentially burn your exhaust valves because the burning exhaust gases will escape faster than they finish burning
backpressure = torque and torque = feeling faster
but the point is to slow the exhaust gases down enough to do a full burn
xcaptainxbloodx
 [thumbsdown]
its the motorcycle equivalent when highschool kids put a fart can on a honda.
wannabfast
Quote from: xcaptainxbloodx on May 13, 2012, 08:39:24 AM
[thumbsdown]
tell that to all the harley guys.... [coffee]
xcaptainxbloodx
wannabfast
im agreeing with the motion that its like a fart can for the hondas
Dirty Duc
Quote from: wannabfast on May 13, 2012, 08:28:15 AM
exactly!
not exactly...  [leo]
significantly changing the flow of air through the motor (cams, exhaust, intake, compression) will result in a change in fuel requirements.
too lean = higher combustion temps = burnt valves or pistons
too rich = deposits = hot spots = burnt valves or pistons
"Backpressure" is always bad for performance, because it limits the amount of air the engine can pump to something less than the cylinder's full capacity.  That said, reducing "backpressure" without appropriate changes to the rest of the equation will tend to lean out the fuel mixture.  This topic is fairly complex, discussions of "backpressure" oversimplify the equations.
