Car Land Speed Record Article
Started by Ducatamount, May 15, 2012, 03:24:04 AM
Ducatamount
half fast
link doesn't work for me. :-\
edit...
does now. [thumbsup]
zooom
no...but I think the FIA does have an age/health/fitness limitation
2010 KTM 990 SM-T
Triple J
#3
Cool article.  [thumbsup]
Interesting that they talk about Bonneville, and show a map, but fail to mention that the current world speed record was done at the Black Rock Desert in Nevada because it apparently has a longer suitable area than Bonneville. All future records will likely be done there as well from what I understand.
I think the only real limit now on the record is space. Everything else can be engineered, but no matter what you have to have enough room to get up to speed and then to stop.
Kopfjager
Quote from: Triple J on May 15, 2012, 11:44:49 AM
Pretty cool on board from that day.
Thrust SSC Supersonic Car - The Final Run 66 - Cockpit View - Black Rock Desert, Nevada - 1997
Kopfjager
Ducatamount
Black Rock Desert,Nev.  Huh,I did not know that.How does the surface compare to the salt flats?
half fast
zooom
Quote from: Ducatamount on May 15, 2012, 12:19:52 PM
WELL...there is talk of the salt eroding, it dissapearing, and getting thin by many different reports...so I think there was a need to find an alternate location so as to be able to save and preserve the speed trials and keep them in America...
how it compares the surface or what the surface there is like...I don't know...but expansive space and flatness were the key things they were looking for...
2010 KTM 990 SM-T
The Mad King Pepe'
Quote from: Ducatamount on May 15, 2012, 03:24:04 AM
Is there a limit to how fast they can run?
When a plane goes transonic the sound waves are able to disperse in all directions, but when a land or water vehicle does some of the waves bounce off the surface and destabilize the vehicle. I am over simplifying a ton here, but this is a big part of what the boffins need to figure out.
Triple J
#9
Quote from: The Mad King Pepe' on May 15, 2012, 01:00:15 PM
Should already be figured out since they've succesfully exceeded the speed of sound on land.
Well, it's flat and expansive just like Bonneville. It's a dry lake bed as well, but isn't a salt layer, just a typical dry lake bed. It's nice when it's dry, unbelievably muddy and useless when wet. Very cool place to visit if you're ever in the area just because it is so unique and weird.
Kopfjager
The Mad King Pepe'
Quote from: Triple J on May 15, 2012, 01:07:04 PM
No.
Different aerodynamic shapes, different internal structures, it's not just copy and paste.
Triple J
Quote from: The Mad King Pepe' on May 15, 2012, 01:38:57 PM
No.
Please explain.
As I understand it, transonic is the speed just before and just after the sound barrier is reached. Like Mach 0.8 to 1.2 or so (actual speed varies)...the condition when some, but not all, of the airflow around the vehicle is supersonic. Since the last speed attempt successfully exceeded Mach 1.0 it would seem they've already achieved stability at transonic speeds.
Speedbag
Going to Bonnevillle for Speed Week sometime is on my Must Do list.  [thumbsup]
Quote from: Speedbag on May 15, 2012, 04:07:14 PM
Don't take a car that you care about out on the salt.
It's a death sentence by rustification.
