February 23, 2025, 06:31:15 AM
Is using a chain clip that much worse than Riveting?
Topic: Is using a chain clip that much worse than Riveting? (Read 2227 times)
The ModFather
Duck Off
Monster Magnet
May 19, 2012, 01:53:20 PM »
Got a new chain but no riveting tool. Have clip and rivet links so I can do either. Debating whether to use the clip, take the chain to a bike shop and pay them to rivet it or buy the tool which is the priciest option.
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
Dirty Duc
I'd rather be an anti-
Re: Is using a chain clip that much worse than Riveting?
May 19, 2012, 02:08:53 PM »
I've run a clip for the last 17-18k miles with no problems.
I'm sure some will tell you that a clip-type will surely end in a horrible, fiery death.
I also run the cheapest o-ring chain I can find in 525, because I really don't see the point in paying $20 a link for a splashy color. The cheap ones last as long as the snazzy gold one the dealer put on the first time.
Last Edit: May 19, 2012, 02:11:30 PM by mergatroyd
Ducatis on the Salt
The Bacon Junkie
I have a Bacon Wrapped
Save the brass...
May 19, 2012, 02:37:52 PM »
It depends on what bike you have, how much power it's putting out, etc...
When I had my little M750, I used a clip style link, but with the 999, I wouldn't dream of it!
The Monster put out around 60ish hp, but the Trip-9 puts out more than double that!
The rivet master is just stronger. I bought the chain riveting tool. It'll pay for itself.
If you decide to go the clip route, make sure the open end of the clip is facing AWAY from the direction of pull!!! Bad things can happen if it's installed the wrong way.
Save the Brass...
memper
May 19, 2012, 04:26:43 PM »
IMO tools are probably one of the best investments one can make. $45 plus you gain the satisfaction of having done the job yourself.
xcaptainxbloodx
May 19, 2012, 06:27:34 PM »
a clip style master link threw the chain off my buddies XS650 as I was riding it from portland to missoula I was cruising at 60 on a bike that maybe makes 25hp on a good day, new-ish chain with about 300 miles on it..
Ive heard many similar stories, so many that the shop I work at refuses to use clip style master links. I have never heard any similar stories about properly installed rivet links.
a clip style may not be the end of the world, but a rivet link is piece of mind. whatever it costs to do it the right way will be a small fraction of what you would pay were the clip to come off, throw the chain and have it destroy your cases or lock up the rear wheel and throw you off, and that only needs to happen once.
Bill in OKC
S4Rs
May 19, 2012, 06:54:34 PM »
Quote from: The Bacon Junkie on May 19, 2012, 02:37:52 PM
I don't know exactly when rivet links became popular but clips were standard for years and years. My '75 GT550 uses a non o-ring and clip master chain as stock. That bike is good for maybe a little over 100mph. I would probably draw the line at 100mph and go with a rivet above that. I suspect most clip failures are when the clip is installed facing the wrong way or otherwise not seated correctly.
Last Edit: May 19, 2012, 06:59:36 PM by Bill in OKC
'07 S4Rs '02 RSVR '75 GT550 '13 FXSB '74 H1E '71 CB750
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
May 19, 2012, 11:08:36 PM »
Quote from: Bill in OKC on May 19, 2012, 06:54:34 PM
I agree. I rode bikes for years using nothing but the clip-style link.... never once had any problems as a result. I use rivet links now coz I can... but I dont see the descent of impending doom if you used a correctly fitted clip-link.
All that said, my advice is: Buy the tool
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Desert Dust
Ten Most Popular Uses for a
May 23, 2012, 07:41:52 PM »
+ 1 on the direction of the clip; clips must be installed with the closed end of the clip facing in the direction the chain travels.
That being said, I rode dirt bikes for years in the 60s, 70s, and 80s and I do not remember any other device other than clips being used to connect the chain. I have, however, been the victim of a clip that dislodged. I prefer the rivet rather than being stuck out in the boondocks with a punctured case.
May 23, 2012, 08:27:16 PM »
As others have said, back in the day, clips were all there was, and they worked fine, as long as you *didn't* ravage the clip or install it backwards.
I've had two bikes with recent clip-style master links come in the shop with no clips.
Failure was averted due to the design of recent clip-style masters requiring a healthy push to install the sideplate.
Back in the day, the sideplate slipped on, no push required.
Not the case these days.
corey
'06 Tang/Black S2R800
May 24, 2012, 05:09:24 AM »
i've heard of screw-type master links. what's the deal w/ those?
Bill in OKC
S4Rs
May 24, 2012, 07:41:02 AM »
Quote from: Speeddog on May 23, 2012, 08:27:16 PM
I saw a thread pic recently where a rivet master had the side plate pressed on but the end of the rivet had not been flared. The bike had been ridden a while like that. Lucky that the side plate stayed on but it does take a bit of a press to get them on.
zooom
May 24, 2012, 08:07:11 AM »
the other suggestion when using a clip that I learned many moons ago and use when using a clip chain link is to put a dab of RTV on the clip as a small dab of insurance to keep from losing the clip...
2010 KTM 990 SM-T
manwithgun
May 24, 2012, 09:39:24 AM »
Quote from: zooom on May 24, 2012, 08:07:11 AM
I do this as well. For those that don't know, it's silicone rubber (room temp vulcanizing) in a tube. Like Frank's Red Hot Sauce, you can put that sh!t on everything (that may be susceptible to vibration and dislodging where locktite is not practical). Oil drain plug is another place where I ALWAYS add a smear of RTV and many tracks require this if you're not already safety wired.
As far as the screw type master, i've got one in the tool kit but have never used it. It's my understanding that by torquing down the 8mm nut to the appropriate depth, the pin is flared and the remaining stud can be snapped off once the nut is relieved... It is not a "screw in / screw out" removable link as the name might suggest.
pic :
http://www.ekchain.jp/feature/index.html
Last Edit: May 24, 2012, 09:43:06 AM by manwithgun
I ride both kinds, Country, and Western.....
May 24, 2012, 06:42:42 PM »
This will work better than RTV:
http://faq.ninja250.org/wiki/File:Masterlinksafetywirednx2.jpg
Spck31
Reply #14 on:
May 24, 2012, 07:26:10 PM »
Quote from: howie on May 24, 2012, 06:42:42 PM
