February 23, 2025, 01:10:07 AM *
Author Topic: How hard or easy to core exhaust?  (Read 1565 times)
joon82
« on: May 19, 2012, 06:58:32 PM »
Just got dremel last week so plan to do some DIY.
I have picture with description but need to know input from people who've done it before.
So is 3-5 hr work worth it?(guessing 3-5 hr)
Any tips to cut the welded tip?
So far I did home powder coat spring,cap,and plate.
Also made shape out of stock cover.
It looks really good from distance but don't like it from close. My first metal/aluminum work.
scduc
« Reply #1 on: May 19, 2012, 08:22:02 PM »
 There is a tread in the tutorials some where. I tried to do my stock pipes and gave up shortly after starting. I did however shorten my SilMotos, and that was not too bad. My guess is that your 3 to 5 hours will probably end up like 6 to 10.
tuxicle
« Reply #2 on: May 19, 2012, 08:46:15 PM »
There's two tutorials I found:
http://www.ducatimonsterforum.org/index.php?topic=56506.0
http://www.ducatimonsterforum.org/index.php?topic=2312.0
2008 M695
Dellikose
« Reply #3 on: May 20, 2012, 05:32:31 AM »
I partially cored / chopped my stock cans. For those, you definately need more then a dremel.
Many say an angle grinder, I used a miter saw with a large abrasive wheel. My cuts didn't like up exactly since I sort of winged it.
The hardest part was grinding down the tack welds to pop the caps off, and then hammering them out.
I followed the tutorials that I found on the forum and they were all that I needed.
1999 Ducati M900
xsephirot
« Reply #4 on: May 20, 2012, 09:23:46 AM »
OP I just did this and used booger's tutorial. It will definitely be more than 5 hours. Cutting apart both exhausts probably took 5 hours alone in time. You will need more than a dremel. The angle grinder is crucial. But note that even the 4 1/2 cutting wheel was having trouble reaching the inner baffle to cut at once side is deeper than the other inside the steel casing. I ended up just trying to make a whole diameter cut before I couldn't reach anymore of the metal and just bent it back and worth until it broke since steel is brittle.
Oh, and definitely wear safety goggles, gloves, and a mask.
For me the hardest part was drilling out the riveting holes. That inner steel tip is a pregnant dog to get through.
booger
« Reply #5 on: May 20, 2012, 11:46:12 AM »
bet that full Arrow exhaust is looking pretty good right now Evil
didn't take me 5 hours to cut them up, maybe 2 but definitely not 5
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
xsephirot
« Reply #6 on: May 20, 2012, 01:40:12 PM »
Haha oh yeah there were a few times I was just like @#$%. My rivet holes aren't as straight and beautiful as yours =(
BUT I installed it this afternoon. OMG the sound is intoxicating. All those hours of blood, sweat and a good bit of cursing I will say was well well worth it.
