February 23, 2025, 06:07:07 AM *
Author Topic: M600 Speedo cable and twin headlight conversion problem  (Read 1686 times)
Wildfire
« on: May 26, 2012, 10:16:33 AM »
Has anyone converted to twin headlights and overcome the problem of the speedo cable being bent at a sharp angle as it cannot clear the back of the twin lights?
I have just written off the cable on my M600 after fitting the twin lights.
It seems a choice of moving the clocks up or making up new headlight brackets that push the lights further out.
COP TZR
I got the modding virus
« Reply #1 on: May 29, 2012, 07:01:03 AM »
I ran into this problem myself when swapping to duals.  I have taken the speedo cable off since, which I hate because I cannot gauge how much fuel remains in my tank with the lack of the tripmeter.  I was going to bring the lights forward with some brackets, but it wouldnt look right.  raising the cluster would also look out of place.  the lower everything is, the more streamline it looks.
I then thought of drilling a hole thru the headlight housing and running the speedo cable thru, but that would just be a problem if water ever got in.
I'm giving up on the duals, going back to the stock headlight and probably retrofit an HID kit.  I find the duals give really crappy light.
They are for sale if interested.
Nottsbiker
« Reply #2 on: May 30, 2012, 04:25:58 AM »
Personally I dont like the dual headlights at all as they look too small if they are the ones which fit into the stock light space - Speed Triple style ones would be much better imho.
Have you thought about swapping the speedo for one from say Trailtech or Acewell that uses a magnetic pick up to measure wheel revolutions?
Ducati Monster 900 (project) Aprilia Tuono 1000
brad black
« Reply #3 on: May 30, 2012, 05:29:52 AM »
one of my customers has a bike with them fitted (not sure if he did it or not) and the cable goes through the lh one.
Brad The Bike Boy
http://www.bikeboy.org
COP TZR
« Reply #4 on: May 30, 2012, 06:15:34 AM »
I was going to do the Trailtech swap and have a magnetic pickup placed on the front wheel, but I went thru great lengths to get my hands on a Ducati Performance carbon speedo & tach cluster for my bike and I dont want to give that up.
I swapped back to the stock light, lowered everything and its improved my lighting drastically.  Its personal preference but after having both setups, I'm favoring the look of the lowered stock light setup.  The duals do look a little small for the front of the bike, and I guess I just got tired of that look and poor light output.
They are an easier swap for guys with the speedo pickup that comes off the back wheel.
I now may retro-fit a newer Monster headlight to give the front end of the bike a more modern look.
BG DUKE
A healthy Monster is a happy Monster
« Reply #5 on: June 08, 2012, 12:33:15 AM »
Hi.
Rising the instrument panel about 1/2" with two sleeves was what i did on my bike. Another thing you can do is to lower the headlight bracket. You can find it in the tutorial section.
Mike Qube
« Reply #6 on: June 12, 2012, 12:57:55 PM »
When I switched to dual headlights I started snapping speedo cables like they were twigs. I eventually went to a trailtech unit.
