January 26, 2025, 12:58:10 PM *
Author Topic: Exhaust leak 2011 796  (Read 1630 times)
SteveO.
« on: May 30, 2012, 07:45:05 AM »
Started my bike this morning and was letting it warm up, as it was quite cool and noticed water dripping from the joint in the exhaust right near the springs.  Watched a little closer and could see some "puffs" of exhaust as well, and I'm wondering if this is normal?  I was also wondering if the leak could be making the sound I've been chasing for a while here. http://www.ducatimonsterforum.org/index.php?topic=57200.0 Any answers appreciated.  Thanks. ...Steve
Dirty Duc
I'd rather be an anti-
« Reply #1 on: May 30, 2012, 07:52:34 AM »
My S2R800 eats exhaust gaskets on a regular basis... and it does make a ringing when they are gone.
SteveO.
« Reply #2 on: May 30, 2012, 09:54:15 AM »
So that should be covered by warranty, I'm guessing?  It's only got about 5000km on it so I'm surprised the gaskets would be gone already.  Huh?
Dirty Duc
« Reply #3 on: May 30, 2012, 12:03:00 PM »
I cannot comment on warranty claims for exhaust gaskets... mine is caused by the permanent misalignment resulting from contact with concrete...
Curmudgeon
« Reply #4 on: May 31, 2012, 04:12:09 PM »
There is an exhaust drain back there! When you first start the bike, you get condensation. Drips on your swing arm, right? Totally normal. Cars have those too, don't you know.  Grin
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #5 on: June 01, 2012, 02:58:08 AM »
Swing arms?  Wink
murc585
« Reply #6 on: June 01, 2012, 04:14:53 AM »
I get the same thing, always assumed it was condensation as well. I noticed it more in spring when the temperatures were closer to zero degrees celcius but I haven't noticed it in the hotter weather.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #7 on: June 01, 2012, 04:20:59 AM »
Welcome to our humble abode murc585  waytogo
celcius
do I detect the presence of a commonwealth cousin?
« Reply #8 on: June 01, 2012, 04:22:06 AM »
eh... might be here in Europe
SteveO.
« Reply #9 on: June 01, 2012, 08:22:32 AM »
I realized it was condensation, but it seemed like it was coming from the junction in the system right by the springs and I thought it was unusual to see exhaust coming out from there as well.  You figure it's normal to see exhaust from that junction?  I'm just really trying to figure out a funny noise from the bike and thought this could be it. Thanks. ....Steve
murc585
« Reply #10 on: June 04, 2012, 02:41:54 PM »
I appreciate the welcome ungeheuer! I believe I have already picked your brain with Rexxer questions. I'm quite a while away actually, from Montréal in Canada.
wannabfast
« Reply #11 on: June 04, 2012, 03:31:18 PM »
if its coming from a slip fitting, you can use exhaust pipe sealant, but these usually make it harder to remove after its cured, but does a pretty good job of sealing it up if you let it harden up and use enough
