Loose parts, shouldn't be loose and certainly not where I found them
Started by stopintime, May 30, 2012, 02:03:54 PM
Old oil out.
First part found there.
The rest of them found closer to where they came from.
This doesn't look right.
What are they and where do they come from?
Now I know.
Do you? [cheeky]
corey
sofadriver
clutch bits?
since I run an open clutch cover on mine, I don't have to worry about that stuff. they just fall out on the ground  ;D
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
Quote from: ducpainter on May 30, 2012, 02:34:42 PM
Where is 'closer to where they came from'?  ;D
Closer, as in just below.
All parts are steel, except the tiny alu piece in the bottom of the last picture.
Quote from: sofadriver on May 30, 2012, 02:14:33 PM
clutch bits?
I can tell you that you won't have to fear this [thumbsup] (not open cover related)
sofadriver
Mike in Tacoma
'96 900 SS/SP
IBA 38181
rockaduc
battlecry
So sorry, damn.   Did it sound odd or feel weird at all?   :o
Quote from: stopintime on May 30, 2012, 03:21:52 PM
        :o
I've heard that can happen...on built...
and not so built bikes...
and it's not like you baby yours. ;D
What was the aluminum?
