January 09, 2025, 09:02:27 AM
starter solenoid / relay gone bad twice in two months - another problem?
Topic: starter solenoid / relay gone bad twice in two months - another problem? (Read 1162 times)
annguye1
June 07, 2012, 06:08:34 AM »
Hey guys,
My starter solenoid went bad in April, I replaced it. Rode the bike fine for a month, went to start the bike up last week, same problem - click, no cranking from the starter motor.
So, do you all know of any other issues that might cause the solenoid / relay to go bad?
zooom
Re: starter solenoid / relay gone bad twice in two months - another problem?
June 07, 2012, 06:39:09 AM »
bad ground possibly?
did you replace the solenoid with a brand new one?...have you reached out to the vendor that sold you the solenoid for any warranty possibilities?...what bike is this on?...
I am sure there is a whole host of other questions pertaining to issues surrounding this that others will think of which might possibly answer or lead to your problem...
2010 KTM 990 SM-T
annguye1
June 07, 2012, 07:03:44 AM »
thanks for the suggestion. the bike is an 05 620ie. yep it was a brand new solenoid. haven't spoken to the vendor but i'll have to check with them.
how would i check for a bad ground?
June 07, 2012, 07:11:28 AM »
voltage drop tester
June 07, 2012, 08:50:22 AM »
Does the bike crank if you bypass the solenoid? Did you check that the connector on the back of the solenoid is tight?
