February 23, 2025, 06:26:14 AM *
News: Please Help
Author Topic: Grease on Shaft and Loctite on Threads for Engine Mounting Bolt?  (Read 1197 times)
The ModFather
Duck Off
Monster Magnet
« on: June 07, 2012, 07:43:48 PM »
Putting on a T-Rex Frame Slider. For the Engine Mount Bolt - Ducati says Grease but I'm not sure if they mean on the shaft or the threads. Not sure why they'd put grease on the shaft and typically I do Loctite on the threads. Whats the right way to do this?
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
wannabfast
« Reply #1 on: June 07, 2012, 07:59:44 PM »
NEVER GREASE the threads unless its says, usually grease on the threads means you will probably overtorque the bolts/nuts, grease on teh shaft keeps it free so if you ever have to remove it it can slide out, ive seen many bolts in my day that get seized because of corrosion that may occur, the grease keeps it out
DarkStaR
« Reply #2 on: June 07, 2012, 09:09:56 PM »
When the Ducati manual referes to grease, sometimes it is referring to anti-seize.
Usually, if on the threads, it'll be anti-seize.
If on the shaft, grease.   laughingdp
brad black
« Reply #3 on: June 09, 2012, 09:13:35 PM »
grease on everything.  well, i tend to use anti seize on threads and spray grease (wurth hhs2000) on the shaft and i'd spray it inside the case holes too.
ducati typically didn't change any torque specs when they started greasing things that i noticed.
Brad The Bike Boy
http://www.bikeboy.org
