December 18, 2024, 04:28:06 PM
another charging system question
Topic: another charging system question (Read 684 times)
hydra
life is analog...
June 09, 2012, 10:10:02 AM »
hello folks,
a couple days ago i was out on The Crest and went to pass someone and felt the engine losing power as i tried to get on the throttle. as i passed him i tried to honk my horn and it didnt honk but i felt the engine slightly lose power again. i immediately detoured and headed straight home. got on the 210 and made it halfway before the engine completely die.
got it towed home, charged the battery and put a volt meter on the battery terminals with the engine running. reading was 12.5v and as i started giving it gas the meter started moving below 12.5v and would continue reading less voltage as i gave it more gas.
would this be an alternator problem or the rectifier?
thanks
S4 Foggy- tires, battery...
BE WATER
Re: another charging system question
June 09, 2012, 04:51:06 PM »
Could be either, but it is probably the regulator/rectifier or the connection where the stator wires connect to the regulator. Anyway, easier than doing a lot of typing,
http://www.electrosport.com/technical-resources/diagnosis-center/fault-finding-guide
