Dell PC help with RAID
Started by ducatiz, June 13, 2012, 07:54:38 AM
New Dell Inspiron 620
RocketRaid 2300 PCI-e card
Dell bios sees the rocketraid as a boot device.
But when booting, the RocketRaid bios doesn't come up.
There is no bios disable on the RR card.
Thoughts?
Bad card?
ZLTFUL
I am assuming that you don't want to boot from the PCI-E card correct?
Does the card/attached drives show up in Windows? Disk management?
If it does, then you can set the RAID card to a lower boot priority with your boot drive a higher priority in the PC's BIOS.
Of course, this has all already occurred to you and I am treating you like a simpleton because it has been one of those days already... [laugh]
2012 Panigale 1199
2003 KTM 640 Adventure
new install.  need to set up raid 1 as boot device
derby
have you tried disabling onboard devices or installing the card in different slots?
-- derby
'07 Suz GSX-R750
There's not much to disable.
When I put the rocket raid in, the bios sees it as a boot device.  System comes up but then nothing.  Instructions say Ctrl-H to enter the bios config but nothing on repeated attempts.
I just bought a Syba raide (PEX-40008) which is also a bootable raid controller but it doesn't even show up in the bios.
System works fine otherwise.  I can connect the drive cable back to the m/b and it boots fine into W7.
Boot order is hard disk first, and then the selected hard disks show the RocketRaid when it's in the system, but nothing when the Syba is in the system.
neither have any jumpers to change.
M/b has some jumpers but I don't have a pinout
So I connected the main hard drive back to the mb and booted into Win7 with both cards installed.  Windows immediately recognized both of them and installed drivers.
The system is seeing them but for some reason won't let them boot.   [bang] [bang]
So both cards "work" but the system will not boot to either one, despite both being the INT13 type boot bios.
I have the inline mgmt software running for the RocketRaid, and updated the card's bios to the latest version -- no love.  It sees all the drives I've attached to it.
[bang]
I put the RocketRaid card into (an equally new) Inspiron 560 and it booted right up.  For some reason, the Bios in the Inspiron 620 doens't like having a bootable SATA card in there...   [roll]
d3vi@nt
I imagine you've already checked, but is the Inspiron BIOS the latest revision? Can you get into the RR BIOS/menu with no drives attached to it (though if you can access everything once in Windows, you've already ruled out the drives and cables)?
'13 MTS GT
'99 ST2
'07 M695 - Sold
Quote from: D3vi@nt on June 15, 2012, 09:09:53 AM
Yup, the 620 was shipped with the latest bios (system was built 3/10/2012).
I couldn't get into the RR's bios in any way, nor the Sybex raid.
I put the RR into the Dell Inspiron 560 and it booted right into the bios, no problem.  I've already set up a RAID1 and installed Window Server on it.
The 620 just doesn't like a RAID.  The 560 has an AMIBIOS which is more generic, and I think that's what permits it.
derby
this is regarding silicon image cards, but...
http://forums.anandtech.com/archive/index.php/t-2145271.html
However, I've learned something. I've received confirmation from Dell that (contrary to what two other Dell support agents told me) the Inspiron 620 *does* have a UEFI BIOS (AMI's "Aptio").
Apparently the American Megatrends "Aptio" UEFI BIOS is incompatible with these adapters. Maybe all UEFI BIOSs are?
-- derby
'07 Suz GSX-R750
ZLTFUL
Derby got me on that one. I found the same info and was headed here to post it up. Stupid know-it-all Derby!  [cheeky]
2012 Panigale 1199
