DP Cam Specs (M1100)?
Started by scooterd145, June 13, 2012, 08:09:53 AM
scooterd145
OK, I am doing my 15K service and have collected a few parts to install during the down time. I am installing a set of DP cams, Power Commander V, MWR Power-Up filter kit, Billet Clutch Slave Cylinder, Billet Pee Cups etc.
I want to degree in the cams but need the specs for them. Anyone know these or seen them somewhere you could point me too?
If anyone is considering doing the cams I will point out that 2 of the 4 closer shim stayed the same and the other 2 I only changed because I wanted to get to "adjusting specs" and were prolly close enough as they were within "checking specs" but on the outer edge. The 2 I changed were both Exhaust. I ended up changing ALL of the openers as they were now way too thin.
scooterd145
Oh and perhaps more importantly, I have lost 7 lbs (personally not the bike) so far and have 13 more to go. Would this be considered "unsprung" wait  ;D
scooterd145
Quote from: scooterd145 on June 13, 2012, 08:23:10 AM
Saving 20lbs is a decent performance mod  [thumbsup]   It'd be sprung weight though  ;)
sprung or unsprung depends on if a pretty girl is around.
