December 28, 2024, 03:57:51 PM *
News: Please Help
Author Topic: DP midpipe fitment  (Read 1848 times)
Justang
Here to learn
« on: June 26, 2008, 08:23:01 AM »
I got my exhaust yesterday, Termi slipon kit and the DP midpipe.  I installed last night, but had many many fitment issues.  First is there is an exhaust leak in the crossover.  But if you get the crossover seated where it should be, the lower pipe is about 1/4" away from the rear tire.  Get the pipe away from the rear tire, and you get an exhaust leak at the crossover.  I can adjust the pipes to work loosely, but once you tighten, it goes right back to crappy!  Anybody else have these issues?  Any real fix?  It's the midpipe giving me problems.  I may just put the udder back on... But would hate to do that!
I friggen frustrated!  Whats worse is there are no instructions with the DP midpipe, and the slipons have horrible instructions.  Not that you truely need them, but a little clarification when you are have all sorts of problems would be nice.
Edited:  I wrote collector, when I meant crossover.  DURRRR.
« Last Edit: June 26, 2008, 11:54:59 AM by Justang » Logged
07 S2R1000 | Silver/Black | Full Termi w/ECU & stock air box| Clutch cover | 14t front | Tail chop | CRG bar end mirrors |
Justang
Here to learn
« Reply #1 on: June 27, 2008, 07:23:05 AM »
Took it all apart and remounted it.  Everything is lined up properly on the midpipe, but there is still a leak in the crossover.
And how close are your mufflers to the rear tire?  My lower can is a fingers width away from the tire.  It almost looks like if the suspension bottoms out, it'll hit the tire.
CDawg
S4RS
« Reply #2 on: June 27, 2008, 07:42:55 AM »
You can use a high-temp silicon sealant.
Justang
Here to learn
« Reply #3 on: June 28, 2008, 07:25:43 AM »
I had somebody suggest using "exhaust putty" they said they did it on their SV650 and it worked great.  Apparently it's a putty you put around the inside pipe, slip it on and when the exhaust gets hot it seals it up.  I may do this.
RandyFloyd
2007 S2R 800
« Reply #4 on: June 29, 2008, 09:35:19 AM »
Used this to seal up my exhaust leaks last night.  I had leaks where the s-pipes meet the exhaust and where the s-pipes met the mid-pipe.  Has minimizes most of the leaks.
clubhousemotorsports
« Reply #5 on: June 29, 2008, 12:21:53 PM »
Typical off the rack exhaust issues.
Finding an exhaust that fits,works well and does not leak is like the holy grail. Does not matter what you pay or who's name is on the pipe.
Sorry but a tube of sealant is not a good sign of a well made exhaust. Ducati performance pipes used to have a tube in the box waytogo
since termi makes most of the new dp systems , no sealant. You need to get our own. Roll Eyes
Justang
Here to learn
« Reply #6 on: June 29, 2008, 07:54:20 PM »
I'm gonna get some of that and fix the leaks.
I've been riding it around with the small leaks, and man with the full system and the 14t front sprocket, 1st gear is useless.  Once it his 4k rpm the front wheel just comes up.  It's so fun!  [moto]
