February 23, 2025, 03:39:45 PM
it has begun!!!
Topic: it has begun!!! (Read 7782 times)
BastrdHK
Quit complaining, and ride the damn thing!
Re: it has begun!!!
Reply #15 on:
June 19, 2012, 09:59:04 PM »
Its Mr. Black, our in house father of tuning knowledge. Click his sig, I am sure Brad measured and confirmed those numbers for the cam profiles himself.
M-ROCin' it!!!
wannabfast
Re: it has begun!!!
Reply #16 on:
June 22, 2012, 10:01:36 AM »
got everything wrapped up, and i spun the motor a few times to make sure the timing marks lined up and that nothing was hitting
double checked to make sure i wasnt leaking fuel out of the quick connects
started it up and it idled fine, no check engine light or anything, no weird noises, rode it down to the gas station to fill it up and surprisingly on the stock tune no less, it felt a lot smoother down low than it normally did
anyhoo, took it out on the freeway to wind it up a little, and it feels like it starts to really pull at 7500 and i think the power peaks close to 8k
if you have the means, i would HIGHLY recommend putting in 1100ds cams in the 796 motor, i need to dyno tune it and adjust the map, but it feels quicker at the high rpm range, i would really love to see what it does on the dyno
brad black
Re: it has begun!!!
Reply #17 on:
June 23, 2012, 01:48:40 AM »
info from manuals
what are the id numbers on the ends of the cams?
Brad The Bike Boy
http://www.bikeboy.org
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Re: it has begun!!!
Reply #18 on:
June 23, 2012, 02:58:10 AM »
I would be reluctant to install stock cams from the big capacity lower revving motor into the smaller rev happy motors. Just seems like a mis-match to me.
But unlike the OP I have no first hand experience.
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
wannabfast
Re: it has begun!!!
Reply #19 on:
June 23, 2012, 03:38:01 AM »
grind id's are O7C and V7C
but the main thing is that the cams keep the valves open longer than the stockers, which allows for more air and fuel to flow in
and i was pleasantly surprised that it ran on the stock ecu just fine, im sure its not 100% but its good enough to ride and its actually pretty zippy at higher rpm, that being said, i really do need to get some dyno time to get actual number to support this theory, but it is a lot smoother than it was before
brad black
Re: it has begun!!!
Reply #20 on:
June 23, 2012, 03:12:56 PM »
Quote from: wannabfast on June 23, 2012, 03:38:01 AM
is that the 796 or 1100?
Brad The Bike Boy
lawbreaker
Re: it has begun!!!
Reply #21 on:
June 23, 2012, 04:44:58 PM »
Quote from: wannabfast on June 19, 2012, 07:47:50 AM
where did you get this info?
I think that's the first time i've seen someone question Brad.....
wannabfast
Re: it has begun!!!
Reply #22 on:
June 23, 2012, 06:04:13 PM »
Quote from: brad black on June 23, 2012, 03:12:56 PM
the cams came out of a hypermotard 1100s, not an evo, the evo has a different grind id
wannabfast
Re: it has begun!!!
Reply #23 on:
June 23, 2012, 06:30:21 PM »
Quote from: lawbreaker on June 23, 2012, 04:44:58 PM
not that im questioning him, i just was trying to look for that data before
brad black
Re: it has begun!!!
Reply #24 on:
June 24, 2012, 12:44:12 AM »
so o/v7c is the 1100 cam?
what's on the 796 cams?
Brad The Bike Boy
wannabfast
Re: it has begun!!!
Reply #25 on:
June 24, 2012, 04:51:29 AM »
the 796 cams are O/V8P
wannabfast
Re: it has begun!!!
Reply #26 on:
June 25, 2012, 06:59:48 PM »
about 200 miles now, and it feels a little quicker than it did before, the front just about power wheelies in 1st gear, i cant wait to get this thing tuned! i need a new tire first
Re: it has begun!!!
Reply #27 on:
June 26, 2012, 11:00:16 PM »
Quote from: Ungeheuer Esq. on June 23, 2012, 02:58:10 AM
I'm running 1100 cams ergal rollers and flywheel. thing apins like a top gettin into the powerband. fricking love it.
a good tune and pretty certain ill be able to power the front in stock 1st
