it has begun!!!
Started by wannabfast, June 17, 2012, 11:05:53 PM
wannabfast
ok, i have an m796, and i acquired some hypermotard 1100 cams(older not evo) and i started to tear into my engine, scary right?
i have 7200 miles on it, so its just about due for the 7500 valve check anyways, so i figured, might as well swap the cams and do the valve adjust anyways.. whats 2 extra bolts and nuts anyways?
start by removing tank and timing belt covers
then set the cams to tdc via timing mark
i broke my socket i made to get these castle nuts off, so i ended up drilling them out and using a chisel and hammer to knock off the nuts, pretty much destroying them in the process, i have new nuts so thats fine
this nut cracked in half when i used my chisel, they were on there GOOD(crappy cell phone pic)
heres what it looks like without the nut
"new to me" cam on left, stock on the right, looks like its got a little longer duration and more overlap, so more power!!!!
im calling it a night with the vertical head pretty much done, ill tackle the horizontal cam tomorrow
those nuts were one time use anyway
Roaduser
its very hard to tell and prob silly to call from here, but it looks like the cam on the right has more lift.... can u confirm which of the two cams is the 1100 cam, and maybe a better picture?
wannabfast
Quote from: Roaduser on June 18, 2012, 12:21:41 AM
i verified the grind id and it is from a hypermotard 1100, the cam on the right is the stock 796 cam i just pulled out of my engine
its very hard to tell and prob silly to call from here...... maybe a better picture?
true, it is hard to call from those pics.  1100 cam my actually be milder since the bigger motor doesnt like to rev so much....
[popcorn]
wannabfast
well i can tell that it has a longer duration for sure
IIRC: lift is the same across the new air-cooled motor stock cams, 696 & 796 make due w/less duration.
wannabfast
#7
Quote from: Duck-Stew on June 18, 2012, 05:24:53 PM
yea but a longer duration could make more power when fueled correctly
for reference my bike stock pulled 75hp to the wheel
Roaduser
Quote from: ungeheuer on June 18, 2012, 02:13:20 PM
[popcorn]
does the 1100 also have larger valves? another reason for a possible milder lift cam being used in std form.
if its the same lift and longer duration as the op and duck-stew thinks, it could make a nice improvement with some extra fuel. all depends on the heads then i suppose.
wannabfast
im told the heads are identical ;D
wannabfast
heads are identical, valves are not..
1100 are using larger valves. and the heads aren't exactly identical.
cams are just using longer duration/overlap
brad black
lets see if my table works
CAM   I O    I C   E O   E C   IN DUR   EXH DUR   IN C/L   EXH C/L   LOBE SEP O'LAP   IN LIFT   EXH LIFT
696/796   18   60   53   23   258   256   111   105   108   41   11.2   10.8
1000   15   65   62   19   260   261   115   111.5   113   34   11.2   10.8
EVO   14   73   66   25   267   271   119.5   110.5   115   39   11.8   11.2
so the 1100 has a little more duration, same lift and wider lobe seperation (less overlap). might hurt the middle a little a bit.
Brad The Bike Boy
http://www.bikeboy.org
DucHead
Why not start by porting the head for better flow/power?
wannabfast
Quote from: brad black on June 19, 2012, 04:41:05 AM
where did you get this info?
