Can you powder coat the Cam Belt Covers on a 05 Monster 620?
Started by The ModFather, June 19, 2012, 02:35:50 PM
The ModFather
I rattle can painted them followed by  a clear coat but they are now chipping. They appear to be some sort of temperature grade plastic but am not sure if they would withstand powder coating. Has anyone done this?
Thanks
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
Nottsbiker
I thought that PC was only for metal parts due to the powder being attracted electro-statically before being baked on, so either way plastic would be a no-go.
Ducati Monster 900 (project) Aprilia Tuono 1000
It's the baking part that makes it a no go. The powder will stick to plastics... but they would then turn to mush in the oven.
I painted my 620 belt covers - prep is the important part. You must clean clean clean the covers. Then use a primer for plastics and paint for plastics.
wannabfast
or use a flexing agent depending on how you are doing it
rule62
Get a rattle can of truck bed liner. That stuff has been on the belt covers of my 620 since 2005. 25,000 miles later - no chips, no problems.
Pretty much everything that doesn't melt or burn at about 200 deg F can be powder coated with the UV cure powder process.
It's mostly used in large scale manufacturing for MDF and is rarely seen in your local coaters shop though.
