February 23, 2025, 10:18:45 AM *
Author Topic: Definitive Answer RE S2R and S4RS/S4RT Termi Slip-ons  (Read 3543 times)
Ak1nza
« on: June 22, 2012, 01:06:33 PM »
So I purchased a set of S4R Termi Slip Ons (udder back) to see if they would fit on my S2R.  I wasn't 100% sure that it would fit prior to purchase but most of what I had read and searched said that udder-back, slip ons are the same.  Also visually it's not very easy to tell (at least I didn't think so, and mind you I did spend a lot of time looking at side by side pictures of S4Rs and S2Rs).
They are not.
The S4R pipes out of the udder are a larger diameter than the stock S2R pipes and is bent differently.  The cans end up much lower than where the stock ones ended.  Pics attached.
Anyways, just wanted to post it so everyone knew (if they didn't already) and doesn't make the same mistake.  It isn't a big deal to me as I can either sell the set or have an exhaust shop make me some new pipes.  I haven't decided just yet.  Seems that S2R Termi's are quite hard to come by (yes I know there was one on Miami CL, but I had already purchased these before that post).
Bike sounds good with just the udder though!  Ha!   Tongue
« Last Edit: June 22, 2012, 10:20:05 PM by Ak1nza » Logged
2006 S2R800 Dark - SOLD
2007 S4RS
lawbreaker
« Reply #1 on: June 22, 2012, 04:11:03 PM »
Do you have an S2R 1000??
It seems that several of the exhausts for the S2R 800 and S4R are compatible (udder back)..
The S2R1K is a different beast all together.....
uglyducky
something, words, clever . . .
one way to do this is we can all get naked . . .
« Reply #2 on: June 22, 2012, 04:27:50 PM »
those pipes are for an RS/RT . . . which is not compatible with anything but itself unfortunately.
2001 996 Biposto - (sold)
muskrat
« Reply #3 on: June 22, 2012, 04:56:19 PM »
+1
I'm running S2R under tail termi's with a marvin mid pipe and fits PERFECT.  Anything outside the 996 series engine will not be the same diameter as the S2R series.  I too pondered this and had an audience in my garage while doing the work.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Ak1nza
« Reply #4 on: June 22, 2012, 06:54:22 PM »
Thanks for the responses.  I'm not too bent out of shape over this as it's not the end of the world...
I mean I could always just upgrade to an S4RS fit the exhaust now couldn't I?
2007 S4RS
sofadriver
« Reply #5 on: June 22, 2012, 07:08:05 PM »
that seems logical since the RS is such a beast.
so the question remains............are the S2r800, S2r1000 and (standard)S4r pipes the same from the cat back?
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
muskrat
« Reply #6 on: June 22, 2012, 08:33:20 PM »
yes.  you will need a mid pipe or keep the cow udder
2015 MTS 1200
09 Electra Glide
Ak1nza
« Reply #7 on: June 22, 2012, 10:28:28 PM »
Could anyone here with a Termi set for the S2R800/1K/S4R measure the diameter of the inlet on the CF muffler?  I'm curious to know if it is just the udder-to-muffler pipes which are different.  Or are the mufflers different between the 2 systems as well.  That is - would the udder-to-muffler pipes off a S2R/1K/S4R system mate to my muffler cans is what I am trying to find out.
I'm assuming that they would be different due to the increased diameter of the piping but would like to be sure.
Also I've edited the topic to reflect S4RS/S4RT as well.
2007 S4RS
brad black
« Reply #8 on: June 23, 2012, 01:52:08 AM »
the slip on mufflers for S2R800, S2R1000 and S4R (996 Desmoquattro) are all the same.  pipes are 40mm.
S4Rs, S4Rt (998 Teststretta) are 45mm.
Brad The Bike Boy
http://www.bikeboy.org
muskrat
« Reply #9 on: June 23, 2012, 06:12:11 AM »
as reference here's my original set up before I chopped the cans down and replaced the mid pipe.  this will give you a visual of the S4R with S2R 800/1000 termis, granted mine are under tail.
2015 MTS 1200
09 Electra Glide
Ak1nza
« Reply #10 on: June 23, 2012, 09:35:26 AM »
Thx.  That's just what I needed to know.
Muskrat - That's a nice bike.  However I really like the look of the shotgun over the undertail system.
2007 S4RS
Desmofan
« Reply #11 on: July 02, 2012, 03:01:02 AM »
The inlet diameter to the cans on my 2007 S4Rs (testa) are 54mm. This is a full Termi system without the cow udder contraption.
corey
'06 Tang/Black S2R800
« Reply #12 on: July 02, 2012, 05:16:22 AM »
couldn't you just have some shims made? like a small 2-inch long reducer that fits between your new termi pipes and the outlets from your udder?
Ak1nza
« Reply #13 on: July 02, 2012, 06:37:59 AM »
Unfortunately no.  The S4RS/T pipes have a different bend than the S2R/S4R pipes coming out of the udder.  If you see in the pictures I originally posted the lower pipe would end slightly above midway on the rear tire.  To make the S4RS/T slip on set fit on an S2R/S4R you would have to get a shop to bend you some new piping from the udder to the cans, and the piping would have to be 40mm at the udders to fit inside a 54mm diameter at the cans.
2007 S4RS
corey
« Reply #14 on: July 02, 2012, 11:52:15 AM »
bummer man :/
