newer windscreen, older monster
Started by showerfan, June 23, 2012, 10:47:43 PM
showerfan
anyone tried to attach a newer, post 2000 windscreen cowl to an older, pre-2000 monster? is there a bracket i need to be using with a searchable name or part number?
Give me a shout if you know any good motorcycle detailers in the Westchester area.
seanster
member named 118811 should have a pic for you...he had that on his M900 at one point
118811
#2
Quote from: seanster on June 24, 2012, 04:42:46 PM
showerfan
belly pan looks sweet -- which seat is that?
i have the windscreen from an s4r, trying to attach to m900. looks like it will eventually work, i just need to be less lazy.
118811
Quote from: showerfan on June 25, 2012, 04:39:54 PM
Lol!!!
That's what I am running now!!
I ll post pics later
showerfan
dude -- how on earth did you get it to fit? ??? did you buy a bracket, or fabricate one? my life won't be complete until it's attached to my bike. :'( i have a blue one with a white stripe, *and* the matching blue seat cowl with white stripe, thank you ebay.
of course, my life won't truly be complete until i get my cycle cat RIPS system completely installed. or until the penske shock i ordered is put on. or until i get my front-fork situation sussed out. then, when i have my sargent seat, and my new gp gel "capirex" pro grips, then all will be well in the world. [wine]
seanster
Yeah...it never stop...
Unfortunately, i just crashed mine and need some time to clean it up after my shoulder heal up.
118811
Quote from: showerfan on June 25, 2012, 07:54:02 PM
Really hi tech.....currently just using heavy duty zip ties!!!
I have DP tach/speedo that sits higher than the stock so I have the fairing siting atop headlight then resting against the speedo/tach.  I do plan to do something stronger and more permanent
Later
Will post pics when I get home
I
showerfan
classic. i have the dp tach/speedo too. our monsters should meet sometime and make purple babies [laugh]
118811
#9
Quote from: showerfan on June 25, 2012, 10:08:26 PM
Too FUNNY!!!
Sorry, never caught your question about the seat....it's a stock one that I handshaved down and recovered with Alcantara (fake suede) & carbon graphite vinyl.
Quote from: showerfan on June 23, 2012, 10:47:43 PM
Assuming you mean a non-696/796/1100 windscreen.....
You need the late model headlight mounting ears, the special bolts that hold the turn signals, and the rubber grommets.
I'm assuming that you still have the small L-brackets that are attached to your upper triple.
That's what I've done to fit an '02 windscreen to a '98 M750.
showerfan
i do not have those l brackets, though it oops like they would work. i will look for the parts you mention though. for now i may just use some sort of zip-tie/bungie solution like 118811
showerfan
i made it work with 10-inch bungie cords from home depot -- quickly becoming my favorite store on the planet. and they work so well that i can't imagine any reason to find a different, more ``permanent'' solution. i'll post pics in the morning [thumbsup]
JohnEE
Minor threadjack......118811 what clip ons are you using? Nice tach/speedo and belly pan!
118811
Quote from: JohnEE on June 27, 2012, 06:14:56 PM
Thanks JohnEE
The clip ons are Apex with 4'' risers which I have set just below stock height.
