Which power commander?
Started by docwoody, June 24, 2012, 10:10:19 AM
docwoody
So right now I'm putting together a list of future mods to be done on my 2006 S2R1k. I'm set on the boomtubes for the exhaust. If I go with BT do I have to switch to a DP ecu and PC3 or just a PC3. Also is it recommended to mod the intake or leave it stock. I'm trying to maximize performance with the BT.
'06 S2R 1000
wannabfast
i would use the power commander, but it should run fine on the stock tune, albiet wont be at 100% but it should still run
Novelo
So which PC to use because they only made one for the 800 right?
docwoody
Quote from: Novelo on June 25, 2012, 03:36:50 PM
Right that's basically what I was wondering. If I need to go that route.
'06 S2R 1000
ute
All the PC's will fit if its for FI mine is for a 1000 its just the mapping that is different the wiring is all the same connectors.
A PC for a carbi WILL NOT fit a FI Monster
