My Showa forks are 65mm & my caliper is 40mm....help!
Started by Bergweiserus, June 27, 2012, 11:53:02 PM
Bergweiserus
i purchased a set of used Showa non-adjustable forks to replace the
terrible Marzocchi non-adjustables without checking to see if the caliper
spacing matched........and of course since i didn't check, they do NOT match.
The spacing on the forks: 65mm
The spacing on the caliper: 40mm
do i have any reasonable options besides buying a new caliper with 65mm
spacing?
i guess i could put new seals and oil in my old crappy Marzocchi's but that sucks
and i already bought the Showas.
thanks for any advice  :)
'99 Dark with '94 large-valve 900.  Tons of mods...
2003 K1200GT...a few mods..
2011 Multistrada 1200S...lotsa mods (it's a beast)
http://www.yoyodyneti.com/ProductInfo.aspx?productid=70.2005RL
edit...
not sure it's a very cost effective option  :-\
COP TZR
I've got a left side 65mm caliper that I can help you out with.
Bergweiserus
Quote from: ducpainter on June 28, 2012, 02:51:53 AM
edit...
Thanks DP.  I was poking around on the Yoyo site last night and didn't find that one.
Bergweiserus
Quote from: COP TZR on June 28, 2012, 03:44:52 AM
Sending you a PM.  Thanks!
Quote from: cayman s on June 28, 2012, 12:58:58 PM
Also, your current fender may WILL not fit your new forks.
Fixed.  When Ducati went to 65mm, they also went to the plastic band that attached the fender to the fork.  There are black and white plastic bands.  White positions the bolt in-line w/the groove the band goes into, the black does a slight (5mm) offset.  I think you'll need the black ones (IIRC).
corey
might be crazy talk, but maybe just sell the forks and make your money back, and find a proper set?
Quote from: corey on June 28, 2012, 01:15:54 PM
Not crazy, but they stopped using the 40 mm mount in '99 IIRC.
I doubt a set of adjustables would be an easy find.
Bergweiserus
There are also these:  http://motowheels.com/i-8518113-corse-dynamics-axial-caliper-adapters-65mm-to-40mm.html
Also, your current fender may not fit your new forks.
Cayman, those are super cool, thanks!
the front fender issue might be moot at this point; i pulled off my front a couple months
ago  [evil]
i might use some of the plastic clips as suggested by Duck-Stew if i change my mind, though.  thanks for
bringing it up, however  [thumbsup]
Bergweiserus
#9
not crazy.
at this point i am trying to find the quickest, easiest solution (without having to
rob a bank) because i need to get on with it......my Marzocchis lost their oil a LOOOONG time ago  :(
TitanMonsterS4R
The Power of the DMF compells me.  I have s set of non-adjustable S2R forks sitting around.  If you cover shipping from DC, I'll happily drop them in the mail.
I also have a pair of goldline brembo 2-pad calipers that will bolt right up to the fork.  They are 65mm.  $200 bucks and they are yours.
Go figure you could have forks and 65mm calipers by the middle of next week if you want.  Just PM if interested.
These are the calipers I'm referring to as well.
Bergweiserus
Quote from: MonstaS2R on June 28, 2012, 01:56:16 PM
The Power of the DMF compells me.  I have s set of non-adjustable S2R forks sitting around.  If you cover shipping from DC, I'll happily drop them in the mail......
sending you a PM.
Nibor
Quote from: ducpainter on June 28, 2012, 01:18:14 PM
actually there's usually a few sets on Ebay. you're after 900 fors i'd say, theyre the adjustable ones i think. i was lucky, got me a brand new set with 40mm mounts from the Netherlands for $600. you can often find a few pair of 2nd hand on ebay for around $400. they're a fair side better than the non-adjustable crud  ;D how much did you pay for your non-adjustables?
Quote from: Bergweiserus on June 27, 2012, 11:53:02 PM
spacing?
change the adapter from the Marzocchis to the Showas . . .
Bergweiserus
