October 31, 2024, 12:45:36 PM *
Author Topic: Has anyone ever made their own clutch cover gasket?  (Read 1080 times)
K3V1N
« on: July 12, 2012, 09:40:57 AM »
Going on a trip and the gasket I ordered forever ago isn't going to be here in time.
BK_856er
2007 M695; 2004 749s
« Reply #1 on: July 12, 2012, 10:03:46 AM »
In the absence of the accurately die-cut and very thin CA-cycleworks gasket, I'd go with ThreeBond 1194 or equivalent.
I love DIY as much as the next guy, but making large complex gaskets sounds like quite a nuisance.
BK
Omnipotent Potentate
Personal Pretext
« Reply #2 on: July 12, 2012, 10:22:17 AM »
I'm assuming this is the accessory case to main case gasket - not the rubber one for the dry clutch cover. If it's for the big bits, Ducati uses a sealant and the shop that helped me with a leak dis as well. Looks to be the ThreeBond 1194 - grey rubbery. The 1194 seems to fit the bill.
Just remember that you only need a thin bead - don't goop it on. And remember to circle any bolt holes - not just going on one side or the other
K3V1N
« Reply #3 on: July 12, 2012, 10:34:11 AM »
I'm really need the big rubber gasket for the clutch cover. It will be at my door when I get back from my trip but since I'll be on the road for 8 days (2500 plus miles) I was hoping for a little less clutch noise. I made one out of 2 pieces of cork gasket material and it seems to work fine. I'm a little nervous about the heat. I was thinking about taking it off and putting a bead of high temp RTV on the cover letting it setup then installing it so I don't get goo on the clutch plates.
Personal Pretext
« Reply #4 on: July 12, 2012, 10:36:32 AM »
The rubber one has brass spacers built in - be sure you have enough clear space if you DIY something.
K3V1N
« Reply #5 on: July 12, 2012, 11:00:44 AM »
On my cover the spacers seem to be attached on all but the 2 bigger holes. I think what I have works I'm just a little worried about and heat and the cork. I guess I just watch for smoke Smiley
« Reply #6 on: July 12, 2012, 12:36:53 PM »
I would use home faucet washers the same or a little thicker than the original gasket and call it a day.  The open space will allow venting of the clutch (good).  It will be noisier though.  Since the clutch plates are new the noise level shouldn't be that high.
scduc
« Reply #7 on: July 12, 2012, 04:32:59 PM »
Do you really even need a gasket there? Other than to keep crude out.
« Reply #8 on: July 12, 2012, 07:35:59 PM »
No, but the cover does need to be spaced out
K3V1N
« Reply #9 on: July 23, 2012, 09:31:35 AM »
Just so you know if you make a gasket out of cork it won't catch fire. It works great but now that my real gasket is in (it was waiting for me when I got back from my trip) I'll be back to Ducati approved rubber.
battlecry
On a silver black phantom bike...
« Reply #10 on: July 23, 2012, 09:56:48 AM »
Ducati approved rubber?
zooom
« Reply #11 on: July 23, 2012, 10:00:59 AM »
YEAH...kinda like a surgeon general approved condom...but different!
2010 KTM 990 SM-T
